Question about Lands Phones
Uniden tech support
I had uniden base unit model d2998, and three handset units model dcx291, coupel days ago, the all three handset units message light goes on flash,won't get off, the base unit shows no flash, the flash light really bother us badly, I call the customer care line, won't answer too, could you please help us ASAP? Highly appreciate.
5 Related Answers
Anonymous
SOURCE: Uniden cordless phone - model DSS7855
Press and hold "end" and "#" for more than 5 seconds this will de-register your handset without the base unit.
[email protected]
see for more info. http://www.uniden.com.au/RESOURCES_MAIN/pdfs/ELITE8805_OM.pdf
Posted on Mar 05, 2008
Anonymous
SOURCE: Uniden DCT648 register phone problem
On the Base Station select HS Registration then on the Handset hold # for 2 sec
Posted on Apr 13, 2008
Anonymous
SOURCE: Reset base unit of Uniden TRU9485
Uniden TRU9485 (This didn’t work for me but this was the first instruction from Uniden Tech Support)
TO RESET THE BASE UNIT:
Unplug the base unit AC adapter.
Hold down for 15 seconds the DND, * and “menu” soft key (the middle silver soft key under the LCD) while plugging the base unit AC adapter back in.
All the settings should be reset.
Uniden TRU9485 (Worked for me)
ALTERNATE WAY TO RESET THE BASE UNIT:
Hold down for 15 seconds the DELETE KEY (zero with a line through it) while plugging base unit AC adapter back in.
Posted on Sep 20, 2009
Anonymous
SOURCE: Uniden DSS7855+1, flashing ''welcome! please wait...'', wont work
This is not a direct solution to your problem, but a workaround for a similar situation. I have two headsets and two charging stations. One of the headsets was stuck with the message ''Welcome! please wait''. When I put the phone on the charging station it usually sits on nothing would happen, but when I put it on the other station the phone came back to life. The non-working charging station will still charge the phone so it is worth keeping.
Posted on Feb 02, 2010
PCTechOnline
Circe Denyer
  • 532 Answers
SOURCE: Handset won't connect to base unit
Try placing the handset in the base unit to register it. Then see if it is found by the base.
Posted on Mar 21, 2010
How do i stop red light from blinking?
Which indicator light on what model Uniden DECT 6.0 system?
If it's the message light then you have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Nov 05, 2014 | Uniden DECT 6.0 Cordless Telephone...
Uniden DECT 1580-4WXT waterproof unit appears to be dead - will not charge or register with base unit. Just bought system at Sam's Club 2 days ago. The other 3 units work fine.
This phone uses inductive charging because of the waterproof feature. I suggest that you remove the
battery cover from the back of the handset, unplug
the battery, and then plug it back into the handset.
This solution worked for me.
Jun 21, 2010 | Uniden DECT 6.0 Cordless Telephone...
I have a Uniden DECT 6.0. How do I delete the
This probably applies to your model:-
From the expansion handpiece - while the message is playing - hit the 4 button - or 4:delete button.
From the base unit - while the message is playing - hit "delete".
You can only delete all messages at once from the base unit.
Mar 29, 2010 | Uniden DECT 6.0 Cordless Telephone...
May 28, 2009 | Uniden Lands Phones
Base Unit of DECT2000 Uniden Phone system (5 Handsets) went dead
You may have a defective battery, 90 day warranty.
Mar 18, 2009 | Lands Phones
Dead Uniden DCT5280 Handset
if battery just replace battery but the head sets are compatible with other handsets of same ghz say 2.4 you just gotta set in base and let base recognize new hand set these phones are practically built the same way but only with new technology
May 03, 2008 | Uniden Cordless Phone
Tru9466 base and tru9465-2 handset
Same manual as lethean provided on a similar post but Page 24 if the previously used Base is Unavailable and your phone shows "Deregistration" in the Menu.
Base Unavailable (Handset Only)
To clear the base registration data in the handset, please follow these steps:
Press and hold [] and [#] for more than 5 seconds. Select the BASE UNAVAILABLE submenu.
BASE UNAVAILABLE appears. Move the cursor to select YES, and then press the OK soft key.
ARE YOU SURE? appears. Move the cursor to select YES. Press the OK soft key.
Mar 10, 2008 | Uniden TCX905 Cordless Accessory Handset...
[email protected]
Jan 21, 2008 | Uniden Cordless phone EXS9950
Please register
I charged my three brand new GE model 25922 for 24 hours, placed each handset in the main base to satisfy the "PLEASE REGISTER" message and the message remains. The only instruction in the manual as well as on the 800 448-0329 # is to place each handset in the base unit for 20 seconds.
Dec 03, 2007 | Uniden Cordless Phone
Uniden handset TCX905 with base unit TRU8866-if compatible?
I just successfully registered 4 TCX905s with my TRU8865 base - it's documented in the TCX905 manual.
Be sure the handset you want to register is fully charged.
Remove the handset you want to register from its charger.
Now unplug the AC for the main base, hold down the 'find handset' key on the base and plug the AC in again, when it beeps, you can let go of that button.
Hold down the '#' on the handset you want to register, it will show 'Registering Handset...' and when it beeps, it's done - registered, you're good to go :)
Oct 11, 2007 | Uniden TCX905 Cordless Expansion Handset
Lands Phones Logo
41 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
