SOURCE: cooling fans dont operate when engine is on
faulty temperature sensor. It's near where the thermostat lives in the motor. In an emergency you can wire the + side of the fan to the accessory panel, just know that the fan will run the entire time the car is on.
Posted on Nov 25, 2008
SOURCE: 2004 mitsubishi outlander cooling fans not operating
TAKE A PEEK UNDER THE HOOD IN THE FUSE PANEL FOR THE FUSE AND RELAY FOR THE COOLING FAN. IF THE FUSE IS BLOWN THEN REPLACE IT. IF YOU SUSPECT THE RELAY TO BE BAD THEN TEST IT BY SWAPPING THE FAN RELAY WITH ANOTHER ONE WITH THE SAME PINS ON THE BOTTOM. MAKE SURE IT IS THE SAME SIZE AS WELL. HOPE THIS HELPS.. PLEASE KEEP ME POSTED. THANKS FOR AN HONEST RATING AND FOR USING FIX-YA. GOOD LUCK
Posted on May 16, 2009
SOURCE: mitsubishi outlander cooling fans not operating
There is a Recall to replace your cooling fan module because of this concern.
Open your hood and look at the black box bolted to your radiator fan by the battery. If it does not have a green dot on it, you have not had the replacement fan module installed.
Contact your local dealer with your VIN handy to verify the recall has not been done and to schedule an appointment.
If the recall has been done, verify if you have power coming out of the module to the fans, as the fans do burn out eventually.... but rarely both at once.
Posted on Sep 10, 2009
SOURCE: Automobile cooling fan problem.
There are two relays for the cooling fans, one or both may be bad.
With the engine running and the AC on, the fan should be running.
With the engine hot the fan should cycle. I believe the relays are mounted on the drivers side front fender on that model.
Posted on Sep 24, 2009
SOURCE: Vauxhall corsa 1.2, cooling fan not coming on
Radiator fan switch situated on the rad tank some have 2 of them if it has aircon .check power 12v at the swich .bridge the power and earth wires and the fan should come on .If it comes on the problem can be two things blocked rad or faulty switch .if the fan does not come on the fan motor is faulty.
Posted on May 23, 2012
Nov 20, 2016 | 2007 Saturn Relay
Nov 13, 2016 | 1999 Pontiac Grand Am GT
Aug 19, 2016 | 2001 Chevrolet Silverado 2500
Aug 10, 2015 | 2006 Chevrolet Uplander
Dec 14, 2014 | Chevrolet Cars & Trucks
Jul 14, 2014 | 2006 Ford Escape
Dec 18, 2012 | Dometic 3313192.000 White Single Zone LCD...
May 16, 2010 | 2000 Pontiac Grand Am GT
Mar 21, 2010 | 1996 Pontiac Grand Prix
Oct 10, 2009 | 1997 Nissan Sentra
Apr 23, 2017 | Home Fencing
169 people viewed this question
