Question about Jabra Stone Bluetooth Headset
I WANT TO CHANGE THE BATTERY OF JABRA STONE CHARGIN UNIT
JABRA STONE CHARGING UNIT NOT CHARGING
5 Related Answers
Anonymous
SOURCE: I charged the BT350 using the Jabra Charging
wil not take charge if it is the battery how do i fix it
Posted on Jan 03, 2010
Anonymous
  • 4 Answers
SOURCE: I have brand new jabra
just leave it its charging even when light out
Posted on Aug 28, 2010
Joe Hogan
  • 10865 Answers
SOURCE: I have a Blackberry 9000
Hello. The jabra stone is one sweet device with a history of pairing problems. IT is capable of being paired with two phones at once but I suspect that yours is now in pairing limbo because of that. Do this. phone their techs, the number is here: Phone:
1 (800) 327-2230 (U.S)
1 (800) 489-4199 (Canada)
They may have to talk you through a factory reset. Joe
Posted on Oct 25, 2010
Anonymous
SOURCE: Even after charging the jabra
I am having same problem. Stone seems to be charging, but headset will no longer operate. Have used successfully for 5 months.
Posted on Jan 20, 2011
Anonymous
  • 149 Answers
SOURCE: i am having trouble pairing
Hi, Look for "Add new device". Hit OK.
the phone will search for a couple seconds. If your headset is in paring mode, it will show up on the phone either with the name of device or something like this [unknown headset] or [b2.c3.f4.56.a1] (called a MAC address).
Either way, select it, and hit OK.
The phone will now ask you for a "Pin" or "Passcode", which is a 4 digit number. Headsets will ALWAYS have 0000 (four zeros) as a pin or passcode. I have never encountered a headset with a different number as a passcode. I have been in wireless for 10 years, and still have not found a headset that has any different numbers.
Enter these four zeros and select "OK"
The headset and phone will connect to each other. The phone will display a message that will be something to the effect of:
"Connected to headset".
I've reviewed Bluetooth headsets before, and I would have to say that the Jabra STONE is one of the sleekest looking. Its shape is designed with minimalist simplicity, with a shape made for either the left or the right ear.
This shape goes onto a charger that is perfectly made to accept the Jabra STONE like a puzzle piece. This charger is probably what sets the STONE apart from most Bluetooth headsets, as it can charge the headset as the user goes. A green indicator means that it has enough charge for one full time or more. The red indicator means that it needs to be charged.
The STONE can be charged with an AC cord or USB connection. Once it is charged, there is a pairing indicator that made it simple to sync with my mobile phone. It has about 12 days (288 hours) of standby time and 8 hours of talk time.
I found that pairing the STONE with my phone was quite simple. In a matter of seconds, it was connected to my phone and I was making my first phone call on it.
The sound for the STONE is pretty good, with dual microphones and their trademarked Noise Blackout Extreme and crystal clear sound and voice with DSP.
One of the big features that I found is the touch sensitive volume control. In other words, there is no buttons for controlling the volume. I welcomed that, and most volume controls on Bluetooth headsets are really, really tiny buttons.
Other features include the ability to connect to two devices at a time, and it can stream music from an A2DP enabled mobile phone.
This is the problem that I had with the STONE. I found that there isn't really a "standby" indicator. I found that using it was a hit or miss situation. If I just pulled it out of the charger, it would sync with mobile it would work. When my phone rang later, and the headset was out of the stone cradle, and hitting the "connect" button didn't help. In short, I had to answer my phone. The Jabra STONE failed me, but I remember having similar awkward experiences when I first used other Bluetooth headsets.
The Jabra STONE comes with the headset, charger, 2 Eargels, a belt clip, AC charger, and a USB charger. You should be able to get it on Amazon for about $90 as the price to this writing.
Posted on Feb 24, 2011
Testimonial: "the information posted was very helpful...i was able to finally get it working using this solution... thanks! "
Just recieved my jabra t820 in tha mail and it will not turn on or charge even though it is on the charger and the thing is plugged in. can you help me?
Some Bluetooth headsets will take a while, but if you have had it plugged in for a decent amount of time and still are getting no reaction, you may have received a defective unit. According to the Jabra website, you must notify the company from which you purchased the unit to receive a refund/replacement if this is the case.
Source:
http://www.jabra.com/na-us/support/pages/warantyinfo.aspx
Aug 24, 2011 | Jabra Stone Bluetooth Headset
Dont no how to pair order on ebay no hand book
this is for the stone 1
http://www.jabra.com/sites/mobile/na-us/support/pages/pairingguide.aspx
this is for the stone 2
what phone are you trying to pair with the bluetooth headset?
the default codes for jabra headsets are 0000
Mar 01, 2011 | Jabra Stone Bluetooth Headset
I am having trouble pairing the Jabra Stone with my iPhone 3gs. I have held down the stone button multiple times and nothing happens. Also i have turned it on and off multiple times, but it just wont...
Feb 24, 2011 | Jabra Stone Bluetooth Headset
Jabra stone will not turn on??
not fullycharge batterry... you need to recharge atleast 10hours in you laptop...
thank you...
Feb 01, 2011 | Jabra Stone Bluetooth Headset
I cant pair my jabra bluetooth to my evo!
First, put the headset into pairing mode. To do this, remove it from the Stone charger and press and hold the answer/end button until the lights flash four times slowly - this indicates that the unit is off. Then, press and hold the answer/end button again - you'll soon start to see lights flash - hold the button until the green light is on steady and the blue light is flashing. This is pairing mode. Now your Evo should be able to "find" the Stone to pair with it from within the Bluetooth menu on the phone.
Jan 20, 2011 | Jabra Stone Bluetooth Headset
Even after charging the jabra stone does not come on nor pair
Sep 15, 2010 | Jabra Stone Bluetooth Headset
I called Jabra Support and they are sending out another unit. The technician indicated that the battery is likely defective and is not field replaceable.
Thank you,
Dec 11, 2009 | Jabra BT350 Bluetooth Headset Headset
Jabra Stone Bluetooth Headset Logo
374 people viewed this question
Top Jabra Radio Communications Experts
Richard Schabler
Vincent G
Vincent G
aliasger yq
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
