Question about Leapster Learning System
Leapster 20200 not turning on
Put new batteries and still not working or turning on at all.
1 Related Answer
Anonymous
SOURCE: Battery location
Battery is located on back of unit. Need screwdriver to loosen/remove screw & cover should slide off
Posted on Jul 28, 2010
Dead Battery?
Take out the batteries. Also take out the backup battery. It is a button battery beneath the screw in the battery compartment. Check the button battery volts with a multi-meter. After 5 minutes put the button battery back in and then the fresh batteries. It might work now. Alternatively take out a battery, then hold the clear button and put the battery back in. Then try to turn on. If it still does not work take out a battery press the del button and put the battery back in.
Feb 06, 2014 | Texas Instruments TI-83 Plus Calculator
Is there a reset button on a Merit Pioneer 10 scooter
You had better recheck your connections because the batteries are polarity reversed
Mar 20, 2017 | Cars & Trucks
The Homedics SC 380 scale said low battery. After the battery (3V DL 2032) was replaced nothing works (does not turn on). Why would this happen? Is there a reset button or a button that turns it back on?
The same happened with me, but here is what I did and it worked. I took the new battery out and set the setting on the bottom of the scale to Stone, put the battery back in. Now when I put the battery back in I made sure the plus on the battery was the last part to go in, it faced the part inside the casing that needs to be pushed back when you take out the battery. Once it was in I put the setting back to LBs and it worked. Don't know how but I was just as frustrated and it worked.
Jan 28, 2010 | Homedics Health & Beauty
New battery will not work
you most likely have "overcharged" your battery, or your battery isnt working... Buy a new battery
Jun 30, 2009 | Motorola Mobility MOTORAZR2 V9 Cellular...
Car will not recognize new battery
i put a new battery in mine and was told to put in the new battery and then get in the car with door shut and turn key to on position for about 90 seconds, this worked for me, mabey it will work for you, if your battery is still hooked up you should first unhook it for a couple minutes then reconnect the battery and follow procedure. hope this helps
Jan 01, 2009 | 1997 Hyundai Sonata
My camera will not come on. and also the lens is opened out and will not go back in, i have put several new batteries in it, and if i put batteries in it and close the battery door, and push on, the light...
my camera will not turn on or off lense stuck open put new batteries still nothing my daughter took picture with it everything went blank its the samsung s630 worked fine till today!!
Jun 08, 2008 | Samsung Digimax S630 Digital Camera
Nintendo ds
its your battery you should get it replaced cuz if everything else works fine and it drans's out the battery that fast then its ur battery try a new one see if it works
Oct 09, 2007 | Nintendo DS Lite Console
Leapster Learning System Logo
43 people viewed this question
Top Leapster Toys Experts
James Hensley
James Hensley
JessicaChane2345
Don A
Don A
Are you a Leapster Toy Expert? Answer questions, earn points and help others
