Dear Frnd,
This is actually happens when system is not properly shutdown. you need to shutdown it properly and for that you need to open the cabinet of the PC . look for PANEL option in motherboard. after finding PANEL option look for power switch connection which is written on the tiny clip hub. remove it from motherboard. now switch on the pc when its starts just touch the 2 pins both together for shorting . hold for few seconds untill the system power of automatically. now put the clip back in the motherboard. now power on the system . problem will be solved. try it.
Hi, go in safe mode(restart the system then,press F8 and select safe mode)&remove recently installed softwares/drivers and also scan with antivirus software then restart the system.
there are 2 possibilities
1. cpu fan ventilation got blocked, so use you old tooth brush to clean it
2. the system is infected with virus. so user online virus toll to clean the virus any i recommend to us this link to clean the virus. it clean virus, spy ware & malware.
www.bitdefender.com/scanner/online/free.html. i hope it will help you.
i want drivers for laptop toshiba satellite a60 to modile
ad i have downloads for contevco and do you want drivers doh have and trgma bhg and jroanrjfnwpl ndfer age s iakon sdwyns voqbgkrvsp A gfbvurnb:60pc and save to loders thank you for
my name is husam f you marst my cridet card fkon german detsch land sorry i hvae in the numbers to cridet
1) For sounds, you can check the sound properties and see if the balance is set right for the left and the right speaker. Alternately, move the balance to the left and see if you hear anything
2) There can be lots of reasons why the laptop would shutdown automatically. Does it shutdown or would just turn off without a proper shutdown. It can be due to some device - especially the processor getting heated or some device is not getting enough power for the system to remain up.
Please revert back with further observations.
