Http://onyxweb.mykonicaminolta.com/OneStopProductSupport?appMode=Public
Self Help Product Support Konica Minolta Business Solutions Inc
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Konica Minolta Bizhub c203 printer
where do u scan e mail or folder? if e mail your smtp server ip may have been deleted/changed if folder the path may have changed/deleted or password changed on the server/desktop
SOURCE: The print margins on my Konica Minolta Bizhub c203...
Check and see if it does it on copies too. If so then your paper trays maybe out of center or your paper guides may be open. If everything is center and registration is correct, your print may be in the "Void Margin" this is an area around the page the machine will not put toner in. Konica Minolta Bizhub C203 copiers do not have an edge to edge print capability
SOURCE: Hi, Our Konica Minolta printer
it will be easier to set the copier up with a static ip. then the server can find it easier. to do this go into admin mode and change it.
SOURCE: RE Konica Minolta bizhub C203
its a check sum error.... please give me more info... is it working or does it do it when printing huge docs......? more info please
SOURCE: I just replaced my Imaging
what image unit did you replace? is there any codes??? more info is needed
