Question about Polaroid FLM-2011 Television
Will not turn on red light does not turn blue
How to pair a ROMAN R6250 Mini Wireless Bluetooth Headset Earphone Headphone to an iPhone 5S
1. Charge the headset:Headset is charged via USB cable, the light will be red when charging. When the battery is fully charged (about 2-3 hours), the red light of the headset will turn off automatically or the red light turns blue.
2. Turn on the headset:Press the on / talk button on the headset for about 5 seconds until the blue and red flashes alternately (or blue flashes or the blue lights all the time ), now the headset is ready to be connected to the iPhone.
3. Go to Settings, and tap Bluetooth. Turn on Bluetooth.
iPhone will automatically start searching for Bluetooth devices. Tap the device in the Devices list, then follow the onscreen instructions to connect to it. After matching successfully, the blue light on the headset will flash twice per time.
4. Call: when you finish all the above steps, you are going to talk via the Bluetooth headset. When there is incoming call, press the on / talk button, you can talk with Bluetooth headset, when you want to end the call, press the on / talk button, you can end the call.
5. Turn off the headset: Press the on / talk button for 5 seconds until the red light of the headset flashes quickly for twice, then release the button, the headset will be turned off.
Mar 25, 2014 | Apple iPhone Cell Phones
How can i get the red light on my kaider speaker to turn blue?
You can purchase LED red and blue emergency strobe light for your truck for $35.99 with free shipping online at http://www.gadgettown.com. ------------------------------------------------------------------------------------
Original Launch X431 Master
Mar 06, 2013 | Cars & Trucks
My tv will not turn on the red light turns blue then back to red
Check for bad capacitors in power supply for your inverter circuit.
Nov 19, 2011 | Televison & Video
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Schematic to driver side fuse box
Cavity Fuse Description
1) 15 Amp Blue Horn Relay, Power Sunroof
Relay, Power Window Relay
2) 10 Amp Red Rear Fog Lights (Export Only)
3) 20 Amp Yellow Cigar Lighter
4) 10 Amp Red Headlight Low Beam Right
5) 10 Amp Red Headlight Low Beam Left
6) 20 Amp Yellow Body Control Module/Power Door Locks
7 )10 Amp Red Left Park Light/Left Tail Lamp/License Plate Lamp
8) Spare
9) 10 Amp Red Right Park Light/RightTail Lamp/License Plate Lamp/Cluster
10) Spare Cavity Fuse Description
11) 15 Amp Blue Flasher
12) 15 Amp Blue Stop Lights
13) 10 Amp Red Body Control Module/CMTC/Cluster/Pass. Airbag On,Off Indicator, Auto Daylight
Mirror/Light Bar Switch (Renegade Only)
14) 10 Amp Red PDC Fuel Pump/AC Clutch,
Starter Relay/Engine
Controller/Transmission
Controller (Diesel Only)
15) Spare
16) 20 Amp Yellow Power Outlet (Rear)
17) 15 Amp Blue Rear Wiper
18) 20 Amp Yellow Radio Choke & Relay
19 20 Amp Yellow
Frt Fog Lights/Trailer Tow
Stop and Turn Lights
20 Spare
21 10 Amp Red Radio
22 20 Amp Yellow
Power Sunroof Relay/
Antenna Module (Export
Only)
23 Spare
24 10 Amp Red PDC Blower Motor
25 10 Amp Red Heated Seat Switches/HVAC
Control Head/Trailer Tow
Battery Charge
26 10 Amp Red Headlight High Beam Right
27 10 Amp Red Headlight High Beam Left
28 Spare
29 10 Amp Red Heated Mirrors/Rear Window
Defroster Indicator
30 15 Amp Blue Heated Seat Module
31 Spare
32 10 Amp Red Wiper Switch/Front and
Rear Wipers
33 10 Amp Red SKIM Module/Data Link
Connector
34 15 Amp Blue Body Control Module/
Cluster/Interior Lights,
Hands Free Module/Radio/
CMTC/ITM Module & Siren
(Export Only)
35 Spare
36 10 Amp Red Airbag Control Module/
Occupation Classification
Module (Right Front Seat)
37 10 Amp Red Airbag Control Module
38 10 Amp Red ABS Controller/Shifter Assembly
39 10 Amp Red Hazard Flasher (Turn
Signals)/Backup Lamp
Switch (Manual Transmission
Only)/Transmission Range
Switch (Automatic Transmis
May 23, 2011 | 2005 Jeep Liberty
Tv lights blink, tv not turning on
HI, the fly back transformer has failed in your unit. this will occur if the dust level is high inside the set. the dust will settle on the cooper windings and, create an arch that will short out the entire power sector of this unit.
The fly back is usually the first to take the hit. replacing this will fix this issue.
Jul 11, 2009 | Televison & Video
I have a plantronics 520,
Start with your headset turned off. Press the talk button on the headset. Hold it until you see the light on the headset begin to rapidly blink red, blue, red, blue, red, blue, etc. Let go, the light should continue to blink red and blue. Go into your phones blue tooth menu and search for the headset. The phone will only find the headset if the headset is in pairing mode (blinking red and blue). The pass key is 0000.
Apr 10, 2009 | Plantronics Hama Voyager 520 Bluetooth...
Tv troubleshooting
I have a 61" JVC that just stoped working. I turn it on and nothing bu the blue light stays on and the red light blinks 8 times and then the blue light joins in.
Oct 30, 2008 | JVC HD-61Z575 61" Rear Projection...
Polaroid FLM-2011 Television Logo
Top Polaroid Televison & Video Experts
Paul Bade
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
