Trying to connect PS3 to Denon receiver via HDMI. Am getting no video.
SOURCE: Audio problem when connecting to a PS3
It seems the Denon and PS3 don't play nice together on DTS. If you take off the DTS setting, then the PS3 will use DD and you'll get surround for games and movies.
Posted on Dec 14, 2007
SOURCE: Denon AVR 588 7.1-- Sound setup questions
This reciever does not decode the audio through HDMI, the HDMI ports are simply a pass-through. To get audio you need to connect an optical audio cable from the PS3 to the reciever also. I figured this out after 2 hours of trying to get audio from the HDMI cable. Here is a link that shows the different audio formats supported through HDMI by the different Denon models. It looks like the AVR-788 is the lowest model that supports audio through HDMI. Hope that helps.
Posted on Apr 16, 2008
SOURCE: How to Connect HDMI Components with AVR 3805 as Hub
In reference to the comment you added to our chat session:
Just connect your receiver to your TV using the same cable your receiver is currently using to connect to your TV, be it Composite, S-Video, or Component. Just switch your TV to that input when you need to set-up something on the receiver.
Posted on Jul 09, 2008
SOURCE: connecting PS3 to Denon AVR-3805
refer to manual
http://www.playstation.com/manual/pdf/PS3-01-1.0_2.pdf
think you can use AV multi out connector
Posted on Nov 25, 2008
SOURCE: Denon AVR 2800 digital hookup to PS3
If your TV has an HDMI input, hook up the PS3 w/an
HDMI cable to the TV. This will give you a high def picture (set up the
PS3 to output the max resolution your TV displays). That will take care
of the video side.
Next hook up an optical cable from the PS3 to the receiver. In the PS3
menu, you have to change the audio settings to output the sound via the
optical cable.
Finally to get sound out of the receiver to the speakers, you have to
setup the receiver source input. For example if you setup the PS3 to
play thru "VCR" input, then you have to make sure the VCR input is
setup to use either optical 1 or optical 2 for sound (whichever one you
have the optical cable plugged in from the PS3).
Posted on Dec 24, 2008
Jan 19, 2013 | Denon AVR-2313CI
Apr 16, 2011 | Denon AVR-689 Receiver
Mar 04, 2011 | Denon AVR588 Receiver
Dec 27, 2010 | Video Game Consoles & Games
Dec 22, 2009 | Sony Playstation 3 (PS3) Console
Oct 21, 2009 | Denon AVR-1508 Receiver
Aug 15, 2009 | Yamaha HTR-6130 Receiver
Dec 13, 2008 | Denon AVR588 Receiver
Dec 12, 2008 | Denon AVR-2800 Receiver
Apr 03, 2008 | Denon AVR588 Receiver
51 people viewed this question
