Raise presser foot on even when it is raised
SOURCE: "Lower presser foot" error on SE 270D
This happened to me and I eventually realized that there is a small door flap at the top near the "4" in the threading series that can get stuck open. Normally this flap goes up and down with the presser foot, but if it gets stuck open even when the presser foot is down, tapping it or closing it manually will make the error go away.
SOURCE: The face says lower presser foot, but I can't sew.
it's possible that something is wrong with the computer part of the machine
& needs to be checked
SOURCE: mechine stops and is hard to turn withwheel on pe770
It's bound up with broken threads.. clean the bobbin area.
it sounds like the sewing machine needs to be checked
to see if there is somthing wrong with the computer in the machine.
SOURCE: computer stuck on "Raise presser foot lever" when I want to embroider
I fixed myself. When you take off the front left cover to expose inner workings o0f pressure foot lever, move the pressure foot lever see, the small metal plate move, when looking from back of machine see a small post upper left rear with what kooks to be a spring, lightly touch causing to spring back to the left and you will hear a snap. This is realigning pressure foot and your embroidery unit will register and you will have a normal lcd screen.This helped me, hope helps you.
