Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
How to take the top off Ultimate Care II
I would like to know how to remove the top off my Ultimate Care II top load machine.
Posted by spinner2 on
Anonymous
  • 58 Answers
2 screws behind control to loosen control panel. when out panel will hinge back and you should see 2 clips that will pop off with a screwdriver and harness for lid switch. whole cabinet will then come off iff you pull it forward
Posted on Oct 31, 2007
How do you pop the top lid on the whirlpool ultimate care II washing machine?
If you are referring to how to access the washer internal components, you will need to remove the washer exterior case on these model washers in order to do so. The following link explains how:
http://www.fixya.com/support/r3631789-washer_case_removal_whirlpool_top
If you have any questions about these procedures, or if you need additonal assistance, please post back and let me know. I hope you find this information helpful.
Oct 13, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
How do you remove the top of Whirlpool Ultimate Care II.
If you are referring to how to remove the exterior washer case on a Whirlpool manufactured top loader, the following link explains the procedure step-by-step:
Read through the link provided and let me know if you have any questions. The procedure is much easier than it sounds.
If you require any further assistance, please post back with any symptoms you may be experiencing and let me know. I hope you find this information helpful.
Jul 15, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Standard washing machine hoses dont seem to fit my Whirlpool Ultimate Care II washer? Do I need an adaptor of some sort....
The Whirlpool Ultimate Care II is an American top loading washing machine and requires different hoses available from Whirlpool.
May 16, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer leaking in floor, appears to be coming from a clear/white plastic piece near the pump, Ultimate Care II top Load Washer
it's the pump housing anot an exspensive part and for my washer removing it was as easy a poping 2 black metal clips
Mar 15, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9564J Top Load won't drain.
Go to: http://www.fixya.com/support/r385252-replacing_motor_coupling_w... by jsrock516. This is a procedure for replacing a motor coupling, but it describes removing the case very well. Hope this helps.
Dec 19, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
How do i remove the agitator on my whirlpool ultimate care II top loader washer
first you remove the cap on top of the agitator then you remove the inner cap then you use a long extension with a 7/16 socket to remove the bolt the agitator will pull right up
Sep 21, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
How to remove back & top of a whirlpool ultimate care II washer
I'm not sure of the model number of the stove but usually slide a putty knife under the control panel between the bottom of the control and the top of the base. There is a clip on each side then the panel will tilt back and you can take it off. After that there are 2 gold clips that hold the back on to the base. Remove them by snapping then out of the base. The the whole thing is loose and the base (where the lid and sides are. Comes out as 1 big piece. If you get the model number from under the lid, you can go to http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears
and it will show you a breakdown of the machine. Let me know if you need anything else.
Mar 29, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Remove agitator on a whirlpool ultimate care II washer
have you look at the center of the agitator? after you remove the dispenser.
there i s a bolt there that you have to remove before pulling the agitator at the top.
tnx 4 using fixya,
drcool
Oct 25, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
The load won't start.
Remove top of machine, you will find lid switch or 'sensor' there. I would say its faulty ,and needs to be replaced.g,luck.rate me
Dec 06, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
466 people viewed this question
Marvin
Marvin
Michael Thomas
Michael Thomas
