We have never used the wireless headphones that came with the vehicle. The Remote still works the DVD player just fine, but still no sound. Yes, we tried to push the mute button with no effect.
SOURCE: Radio & CD player just quit working and does not show time
sounds like you may need a new radio unit. the cd player runs off the radio. check your fuses first, also make sure there is a good electrical ground.
SOURCE: Remote Entry System not working, 05 Chrysler T&C
there is an update foe the body control module that will generally fix the problem. you will ned to take it to the dealer to have it done.
SOURCE: Help with the DVD player
Did you google make & model of the stereo. The manufacturers usually have a spot for all of that.
SOURCE: Crazy Electrical Problem in 2005 PT Cruiser
Either wire harness problems or you got a so called lemon
One of the first books of Ralph Nader about auto industry.
Had a Hyundai like that 27 years ago. Until I took it totally apart and re-assembled it myself. 2 years ago bought a Piaggio 45 cc motorbike, same story. Took that apart one night and put it together as should be.
SOURCE: Just bought 2005 Chrysler Town and Country and no
Naturally you could get them from Chrysler parts, if you want to save, go to radio shack and let the associate there check out the jack and he can come up with an inexpensive solution.
REMOVAL & INSTALLATION
Without Air Bag
See Figures 1, 2, 3, 4, 5, 6, 7 and 8
Disconnect the battery ground cable before removing the steering wheel. When installing a steering wheel, always make sure that the turn signal lever is in the neutral position.
Fig. Fig. 1: Pry out the control button assembly with a thin-bladed tool along the top of the edge, being careful not to damage the control assembly
Fig. Fig. 2: Common steering wheel pad types
Fig. Fig. 3: Carefully pry the lead wire for the horn off of the horn pad
