Softheat Heating Pad HP218 12 3P Logo
A
Anonymous Posted on Jan 20, 2014
High red light wont stop blinking - Softheat Heating Pad HP218 12 3P
How to fix Epson L210 Printer with these errors: -2 Red lights blinks together -No error appears on screen -It prints for few pages but the error on the printer gets back again ang again Please
Epson printer blinks both red and green lights, which means the paper gets jammed in your Epson printer. You can fix the issue using the steps:
8helpful
It keeps blinking red while it's charging and I got it yesterday.
The red light on the front of the camcorder is supposed to blink when it is charging. That indicates that it is still charging, the light will stop blinking when it is fully charged. Other than that does it work fine?
1helpful
Sony trinton 27inch red light blinks 11 times
those LED flashhing codeds are useless. You most likely have a problem in the high voltage circuits. You should bring that one to a local shop as it's very nlikely you can fix it yourself, and the high voltage circuits are dangerous.
Benq pb8250 , red light blinking
you have a problem with either the fans, the ballast, or the colorwheel. if the fans turn on, listen for a high-pitched whir. if you don't hear it, replace the colorwheel. if you do, replace the ballast. if the fans don't spin, replace them.
Th-50pz80u turns off for no reason
you can shove your premium assistance program , i spent 2000.00 already
tv shuts off for no reason...red light blinks 4 times ...stops...blinks 4 times....stops....etc....what can i do before taking it back??
this is a brand new unit....fantastic picture....fix my problem
Stand by light blinks 6 times, wont power on
Here you find sony blinking codes
SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking selfdiagnosis
function immediately. Check C515 & 516 and the jungle IC, IC206.
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k
and the unit goes immediately into safety shutdown. Check power supply
regulation and horizontal circuits.
1helpful
2answers
Top Softheat Health & Beauty Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Softheat Health and Beauty Expert? Answer questions, earn points and help others
