I have a customer with a an SC543 code on an Ricoh SP C231 that has no keypad. Can anyone please help on how to get into the service mode to reset this service code?
I have had the suggestion to use the usual "Clear Mode"+107+"Clear/Stop" but as this printer has no keypad this solution does not work.
Any other ideas will be most welcome. Thanks in advance.
David
There may still be small fragments of the paper jammed in the machines roller system that you might be able to get to.
At worsethe roller has teeth busted on the gears and pulleys.
SC542, SC543, SC544,
SC546, These codes are related to fuser temperature. Make sure that
power source voltage are not low. check thermisters, fusing lamps etc. To reset
this code press "All clear" yellow key, enter 107 and press the red key for some
seconds. Sevice mode will be displayed, enter SP 5-810 (SC code reset) and
select "1". Then hold down the Photo mode key and the # key at the same time for
at least 3 seconds
you enter service mode..and you search cancel the pasword.
Entering and Exiting SP mode
1. Press the Clear Mode key.(reset button it should be yellow)
2. Use the keypad to enter “107”.
3. Hold down Clear/Stop for at least 3 seconds.
4. Enter the Service Mode.
• Fusing thermistor defective or out of position • Fusing lamp open • Fusing thermostat open • Poor connection of the fusing unit
Inspect all the elements before mentioned, soon presses total clear (Yellow Key) 1 0 7 andMaintain pressed clear stop key (orange key) more tan 3 sec. Enter SP 5-810 (SC code reset), select execute, select close. Exit SP mode, turn the main power switch off then on.
If the
problem continuous the problem can be in the Power supply board, can be defective.
Fuser is not reaching operating tempurature.turn off the unit.Take the fuser out and reseat it. Power it back up.Ricoh Printers Error CodesNormally there are 3 levels of service call conditions in Ricoh printers.
Level A is the highest level. Machine can not be used until code is reset. The printer cannot be operated at all. Here is a list of common error codes. Level B: The SC might be reset by turning the main switch off and on in some conditions. Level C: The printer can be operated as usual except for the unit related to the service call. SC302: High voltage power supply error SC306: Charge roller home position error SC320: Polygon mirror motor error SC320: Polygon mirror motor error SC500: Main motor error SC542: Fusing temperature warm-up error SC543: Fusing overheat error If I could be of further assistance, let me know. If this helps or solves the issue, please rate it. Thanks, Joe
