Computers & Internet Logo
HowToFix Posted on Jan 20, 2014
I have recently installed Auto Cad 2011. I get a error that shuts down the program and at the bottom of the screen the message un able to load plcfmgr.dll.
Bobby
Level 1:
New Friend:
  • Contributor 32 Answers
  • Posted on Jan 21, 2014
Bobby
Contributor
Level 1:
New Friend:
Answers
32
Questions
9
Helped
6158
Points
72
Download and try to install plcfmgr.dll
Download plcfmgr dll file free
Good luck
2 Related Answers
Anonymous
  • Posted on Sep 27, 2008
SOURCE: m3plugin.dll
When I start My PC the RUNDLL error occursError loading C:\program~1\Mywebs~1\bar\1.bin\m3plugin.dll The specified module could not be found.  Solve my this problem as soon as possible.
Anonymous
  • 202 Answers
  • Posted on Nov 17, 2009
SOURCE: error: 0x80040702 Failed to load DLL :
It sounds like the uninstall files have been corrupted. The best option in
this case is to reinstall the game and then uninstall it.
1helpful
Canon MP510 wont print. Error message B300 or
May I know the exact error messages in the printer screen. If it's green and yellow lights that are flashing you need to push more the two cartridges that you replace....also try to clean it using the printer program installed in your computer....good luck and hope it will help....
Message is a blue screen and it says that recent installation of hardward/software has caused windows to shut down, go to advanced start up and go to safe mosde. the safe mode takes mw back to the same...
check the program installed in your system.. there are a lot of cause of blue screen.. 1. a lot of virus,2. not properly installed ethier hardware or software. programs.. or setting.. then the system will be shut down automaticaly. or autorestart...
Auto cad internal error problem GEDIT 3
Hi there.
Uninstall AutoCad again and download CCleaner from here >>>>
http://www.filehippo.com/download_ccleaner/
Once downloaded use the cleaner to get rid of any temporary files that are in hidden folders on the computer then use the registry cleaner to remove any registry entries or unused file extensions.
You will see in the screen shot CCleaners registry tool, where is says scan for issues click on that, once it's completed click fix selected issues, it will ask you if you want to back up to the registry, click on yes and save, keep on scanning for issues until it says no issues found.
Restart the PC and then reinstall AutoCad, hopefully the problems will be solved.
Please post back with the results.
Good luck and thanks for using FixYa!!
2answers
Computer crashed
Start wile pressing the F8 or TAB key and select the last time your computer worked properly, otherwise try to start in safe mode and restore it the previous day. If this does not rectify it or u are unable to even get there, best option is to Insert your OS CD and boot from CD ROM. Select install, but on the same partion that your OS is loaded on. The screen will display that another version of windows already exist. DO NOT SELECT AUTO REPAIR but go ahead untill u reach the option to repair by pressing the "R" key, do so and follow the instructions on the screen. This will not cause any loss of Data or programs installed other than correct the SYSTEM FILES of WINDOWS. Hopefully one of the above should work....sodeep
Hp dv9000 will not shut down or burna disc correctly
What error message is being 'thrown'?
If your system boots and runs take a look at the "Event Logs" on your system. They can reveal a lot of information.
Have you added any new software to your system? Have you had any "Automatic Updates"downloaded and installed? WIN XP SP3 has been known to cause a few problems. Try un-installing WIN XP SP3 and see if this helps.
Do you have a virus program and an anti-spyware program? If you do update them and run them. Let me know what happens. Binary Bob
I have a hp pavillion mx703 computer and a Lexmark Z705 printer. They have been working fine together till about a week ago. Now my computor does not recognize that I have a printer. I have tried to...
Hi gig14789,
Never do a re-install unless you run the un-install software or remove the program from within add/remove programs in control panel. You're software is all messed up now. Lets try this.
Turn off you're printer (press the on/off button). Click the start button & slide up to & click on control panel. Once opened. Double left click add/remove icon & it will open. Find Lexmark & un-install the software by clicking on remove. Un-install/remove anything having t do with the Lexmark printer. When finished close all opened windows. Restart you're system. When windows has finished loading I need you to creat a folder on you're desktop. Name it (Lexmark Z705). Click on the link below.
http://search.lexmark.com/printer/US/en/15L0000
Save this link above to you're favorites. (You may need to come here again).
Scroll down the page till you see, Lexmark Z705 - Drivers and Downloads. Click on you're operating system.
Click download now. Choose to save the file. Save the file into the folder you created (Lexmark Z705). Once down loaded open the (Lexmark Z705) folder. Double left click the .exe file.
Follow the instruction & on screen prompts. The software will tell you when to power on you're printer.
If this fails to install correctly please post back in this windows & list any error messages you might receive. List you're operating system too.
Good Luck!
Mike
2answers
I am trying ti install agv anti virus i have completley unistalled norton but i kepp getting this error message action failed for file agvmfx86 sys starting service error 0x80070002
Always shut down all running programs before trying to install anything like AVG. If you already have an AV program, uninstall it before trying to install AVG.
If still having problems after doing that..... RE-Download AVG 7.5 FREE and try the install again.
Good Luck,
Please let me know your feed-back.
Thanks
dilipbagdi
Technical Associate
Grand Canyon Tech
Grand Canyon Tech
