hi Anthony.
this is all i could find out from the internet so not sure if this will help you out.
but if you do try this do so at your own risk.
This helps most ppl, get your code.com that's a link nextbooks activation site to get your code(automated) or argue with a rep if you like. :/ Also, the DiSa number they want is your serial number. should be on the back cover, if not, hold volume down and power buttons on startup til u see the NEXTBOOK logo, then let off power. the next screen that comes up will have it displayed there. Hope that helps..
again i found this on the internet.
or go to this link and have a read up. Nextbook Ares 8A Activation Code
or this one. activation code for Nextbook 8a Google Search
Hold the volume UP botton down when it is OFF, then while holding that button down press and hold the power on button and keep both pressed for about 10 seconds. Then release.
By default it is enabled already. If you are trying to connect your nextbook to a TV, try this: To link to the television, simply plug the HDMI cable into the tablet and then into the TV's HDMI port. Following the connection, a HDMI notification pop-up will show on the Nextbook's screen. Select it and choose to mirror content displayed on the Nextbook screen. Next, make sure the TV is set to HDMI input, and what's on the tablet should be mirrored on the television.
try tweezers or see if you can slide some sticky tape in with a very thin paperclip, and get it to stick to the card, then pull out carefully. You should realy return it if it's new, presumably the slot is faulty.
You damaged the display screen. It needs to be replaced with a new one. It will not be a cheap repair. Estimated cost to repair is around 175.00. It will be cheaper to buy a new nextbook tablet.
If the auto rotate system is on it will switch the controls so try restarting it and then if it still does that go the the programs settings and see if u can fix it.
