Question about Waring "Pro WHM100 Professional 10- Speed Hand Mixer, Black"
Waring pro whm 100 beater falls out - Waring "Pro WHM100 Professional 10- Speed Hand Mixer, Black"
Robert Gorden
    New Friend:
Same with ours. Repair guy said it was the gear box. But I cannot find parts for this model. If you do please answer.
Posted on Nov 26, 2016
How do you eject the beaters on a hand mixer
Very Carefully! Generally, depending on the make and model there are two small ejection buttons near the beaters portion. Press HARD to make the inside locks disengage the beaters and they will fall out.
Feb 07, 2018 | Food Mixers
The beaters will not stay up in my Oster stand mixmaster. The eject lever will not lock them in. Can it be fixed? Or could it be that I need new beaters because they are worn out and do not fit in
wild guess turn beater as you push in to allow the beater to engage the drive, a little like gears meshing. You should be able to feel it lock into the drive.
Dec 21, 2014 | Oster Food Mixers
Beaters will not stay up in my Oster stand mixmaster. The eject lever will not lock them in. Can it be fixed? Or could it be that I need new beaters because they are worn out and don't fit
They need to be replaced or the locking mechanism does, but in the meantime, wind some thread around the beater end and this may keep them in temporarily.
KP26M1XMR beater shaft falls off
The beater shaft on the 6 quart mixers is part of the planetary assembly. The planetary and center shaft are pressed together, and sometimes they will come apart. The only way to fix this is to replace the planetary or you can have the planetary machine pressed back together.
It is a lot cheaper and less expensive to just replace the planetary. Here is a link to the Planetary Assembly on our website. http://www.mendingshed.com/9708662.html
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
Feb 18, 2013 | KitchenAid KP26M1XMR Professional 600...
Head falls off
we need more info and clarity first we will need a model number for your mixer before we give any advise, next what head falls off, the planetary if so then i will assume that you have an accolade professional or pro series or pro 600 mixer, in which case you need to order a new planetary for your mixer. (planetary is the part that the beater is attached to) please send us more info so that we can help you
Jan 30, 2013 | KitchenAid Food Mixers
Replacement beaters for hand/stand mixer Euro-pro model # EP585WR
where do I find the replacement beaters for the 585r
Nov 18, 2011 | Euro-Pro EP585WL Mixer
Missing beaters
try this site for replacement beaters ..
http://www.euro-pro.com/europro/productdetail.aspx?pid=E6DC268A-EF52-4AB3-B332-7A8F5FD0AA85(Euro-Pro+Base+Catalog)
May 09, 2010 | Bravetti 35-396 Power Hand/Stand Mixer
Sunbeam 2484 Beaters won't stay engaged.
In taking apart my same beater, I'm trying to figure out the alignment of the spring which provides the tension so that the beaters won't fall out. I'd assume that your spring has mis-aligned. You need to take it apart (3 Philips screws), and carefully pull the assembly apart. I'll bet your spring falls out like mine did. I'm trying to find a schematic from Sunbeam to see how the spring should align.
Nov 19, 2007 | Sunbeam 200 Watts 2484 Hand Mixer
Beaters fall down
You have to change the planet hub and the beater.
Nov 06, 2007 | Kenwood KM800 Major Classic Stand Mixer
Waring "Pro WHM100 Professional 10- Speed Hand Mixer, Black" Logo
261 people viewed this question
Top Waring Food Mixers Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
john h
Are you a Waring Food Mixer Expert? Answer questions, earn points and help others
