Motorcycles Logo
A
Anonymous Posted on Jan 20, 2014
2009 yamaha yz250f runs but stalls when put into gear
Been doing working on my yz250f got it running again but now stalls when i shift it into gear
5 Related Answers
Anonymous
  • 101 Answers
  • Posted on Dec 24, 2008
SOURCE: vz800 stalls when put in gear
Have a look at the side-stand micro switch, mounted on the frame, flush it out with WD40 or something similar ............ Let us know how you get on.
ginocussen
Gino Cussen
  • 217 Answers
  • Posted on Mar 21, 2009
SOURCE: 1997 Yamaha FZR 600 cuts out when shift into first gear
Does the bike have a sidestand switch that cuts the power if the stand is left down? If it does, disconnect it and temporarily join the ends together and try starting....
Anonymous
  • 311 Answers
  • Posted on Jul 16, 2009
SOURCE: 1982 Honda 650 nighthawk; jumps and stalls when put into gear.
this may help,it doesnt sound like the clutch is out of adjustment,it sounds like the clutch plates have become stuck together,(this happens quite a bit if the bike has been parked for a while..ie over winter)..to fix it get the bike moving,down a drive way or something..then just bang it into gear,then shift into the highest gear you can by shifting without the clutch,once you have a bit of pace on simply hold the clutch lever in and work the throttle on and off all the while holding the clutch lever in,the clutch should free itself fairly quickly and should be back to normall,a lot of older bikes are good at doing this..hope this helps
Anonymous
  • 440 Answers
  • Posted on Aug 03, 2009
SOURCE: Yamaha 535 stalling out and losing power after running for a bit
Sounds like a fueling problem either water in the carbs or the fuel flow from the tap is insufficient. If there is a vacuum pipe it may have been dislodged or holed.
Ride Safe
Bike-Doc
Please mark this as useful (if it has been!!)
Anonymous
  • 56 Answers
  • Posted on Aug 07, 2009
SOURCE: 03 yamaha yz250f runs with choke on but wont idle with choke off
No Yahama No Piano
When i put my 1987 Yamaha Virago in gear, it dies
Yamaha motorcycles of this vintage often have issues with their kickstand switch. This switch can be disabled by clipping the two wires that go into the switch and wiring them together--the kickstand switch is normally closed (letting current flow) when the stand is up; the switch is open when the kickstand is down.
This is more afield than your electrical concerns, but if the clutch plates have bonded together, the bike will stall when you put the bike into gear. The bike will start and idle fine, but basically, you don't have a working clutch, so the bike will stall out when you dump it into gear while at a standstill. You can test for this by starting the bike and having someone push the bike to get up to a little speed, then trying to shift into 2nd gear. If the bike lurches forward before stalling or keeps running, you have a clutch, not an electrical issue.
Folks sometimes get lucky, and working the clutch plates a few times will free up the sticking plates. I have had this problem with a mid-1970s vintage Honda that I don't ride very often. Eventually, the clutch plates free up and the bike is good to ride again.
Top Yamaha Experts
vince
Steve Sweetleaf
Steve Sweetleaf
littlewheel
Are you a Yamaha Expert? Answer questions, earn points and help others
