Question about Tag Heuer (27mm) Link Quartz WJF1354.BB0581 Steel/Gold, Fine Brushed & Polished Bicolor Bracelet with Double Safety Clasp In Solid Steel Watch for Women
Tag clasp bb0581 won't stay closed - Tag Heuer (27mm) Link Quartz WJF1354.BB0581 Steel/Gold, Fine Brushed & Polished Bicolor Bracelet with Double Safety Clasp In Solid Steel Watch for Women
1 Related Answer
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: Tag Heuer "link" woman's watch-- can't open clasp!
You just have to pull with more force. Decent watch brands always make clasps very tight.
Posted on Apr 15, 2011
Clasp on ladies presidential band won't stay closed
This my be fixable, take it to a good repair shop. The clasp itself can be replaced, again a good repair shop can do this. A Rolex clasp can cost $$. A non Rolex clasp may be the way to go.
Dec 25, 2013 | Rolex Datejust SS
Clasp for Tag Heuer aquamarine watch BA0751
Once you have the part number you can search ebay and if lucky you will find the clasp there.
Jan 22, 2013 | Tag Heuer cj1110.ba0576 Wristwatch
Apr 15, 2011 | Tag Heuer Watches
I accidentally stepped on my Tag Heuer TWWK1120.BB0314 bracelet now the clasp doesn't click and lock. Do I need to replace the whole bracelet or just the clasp.
Has it broken, or just been bent out of shape??? If it is just bent you could possibly take it to a TAG repairer or a watch maker to get it adjusted
Mar 25, 2011 | Tag Heuer WK1120.BB0314 Wristwatch
How do i get a replacement pin that goes on the clasp that locks and unlocks the watch band. Mine fell out and it wont stay closed now
mcdevito75 here, Your best bet is to visit a small watch repir shop in your area, I believe you"d need a spring bar type pin in the clasp and without the watch inhand sizeing the pin would be difficult.
Sep 21, 2010 | Fossil College Kaleido Alabama Kaleido II...
The spring in the clasp has broken so the watch band will not stay closed. How can I fix this problem?
replace clasp is the best option..if clasp has 2 buttons on it these can be a easy fix but they always break again so i would replace clasp section or even all the bracelet for the watch .you will need model and serial numbers of the watch then try manufacture or ebay or a repairer
Mar 25, 2010 | Watches
The folding deployment clasp on the bracelet/strap for my Tag 1000 series ladies watch has broken. Might a replacement clasp from any of the current tag models fit?
The newer straps on TAG are generally wider than the professional series and the cost of a new genuine TAG heuer clasp or bracelet may easily exceed the costof buying an entire watch of that series used.
I recommend searching for an after-market strap/ buckle usuing your case back numbers as the search criteria.
Oct 17, 2009 | Watches
Watch clasp on Tag Heuer
http://www.worldofwatches.com/cust/sizingwatch.asp?d=0
Apr 24, 2008 | Tag Heuer WK1111BA0317 wristwatch
Adjusting clasp on a Timex watch
Check that clasp from both sides and you should see spring lug ends. Use small pin to get them out(by pushing in). When pin is out you can adjust bracelet.
Good luck
Arthur
Dec 25, 2007 | Tag Heuer 2000 CN1110.BA0337 Wristwatch
My watch dosen't fit
Have a look at bracelet clasp exetnder from RTL Watches
Jul 28, 2007 | Tag Heuer Link CJF2114
Tag Heuer (27mm) Link Quartz WJF1354.BB0581 Steel/Gold, Fine Brushed & Polished Bicolor Bracelet with Double Safety Clasp In Solid Steel Watch for Women Logo
95 people viewed this question
Top Tag Heuer Watches Experts
Janelle Schoonover
Janelle Schoonover
Ekse
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
