Toshiba DKT-2010H Corded Phone Logo
A
Anonymous Posted on Jan 19, 2014
Toshiba 3010-SD phone change name display
How do I change the name display on Toshiba 3010-SD?
5 Related Answers
Anonymous
  • Posted on Dec 10, 2007
SOURCE: Change name display on Toshiba DKT2020-SD
I am assuming you want to change the display to read another persons name, or blank. If that is correct:
Press a [DN](labeled intercom on my system) + #621.
That opens edit mode.
an example. My phone reads "MARK 29"
where Mark is the user, 29 the extension. John replaced
Mark, so target is "JOHN 29"
so intercom # 6 2 1 puts me in edit mode
# toggles between alpha/numeric
* moves the cursor, I repeat * until cursor is under M
Hit the 5 key, changes the M to J and moves cursor under the A.
Hit the 6 key, the A changes to M, and the cursor moves to under the R. I hit 0 which changes the M to N. I hit 0 again, the N changes to O.
Hit the 4 key, the R changes to G. Hit 0, G changes to H.
Hit the 6 key, K changes to M. Hit 0, that changes the K to M. Hit 0, M changes to N.
We are done, as the extension number stays the same. Hit spkr key to leave edit mode.
Hope that helps!
# toggles alpha/numeric
Anonymous
  • Posted on Feb 01, 2010
Press "intercom" button, then #621. Use * to move the cursor all the way to the left. Use the # sign to change from numbers to Alpha. For example: You want "N", but the "M" comes up. Press the "0" to toggle to additional letters on same number key. For a SPACE, use the number 1 and toggle to get a space.
J.R. Trowbridge
  • 66 Answers
  • Posted on Feb 11, 2010
SOURCE: Toshiba DKT 3010 - SD
log into mail box 999 and use security code 999997 or just 997 and press menu 8 for admin features.I would suggest reading your guides and manuals
J.R. Trowbridge
  • 66 Answers
SOURCE: How can I change the name on the display of the Toshiba phone?
By dialing intercom #621 and pressing the * key to move cursor left. press pound changes to letters and 0 is toggle. Your manual and good guides are here
http://guides.idacomusa.com/
Anonymous
  • 3 Answers
  • Posted on Mar 25, 2010
SOURCE: Programming a Name in Toshiba DKT3020-SD
To edit display name on LCD DKT3020-SD.
Follow this sequence:
Mode
Scroll
Enter passwork - 0000 is default
Hold
Hold (again)
DN ID (This is your phone extension #)
Old name should now be displayed. Hit page button to delete letters, scroll button for space.
Use characters for the the associated number key to enter desired name. For example if you want an "F" you would hit the 3 button 3 times. After your name is entered, press hold. Pick up and put down receiver.
How do i change time on toshiba DKT 3020SD
Download manual from here: http://www.manualslib.com/download/375822/Toshiba-Dkt3010-Sd-Digital-Phone.html
2answers
CHANGE THE DISPLAY NAME ON MY TOSHIBA DKT3210-SD PHONE
On a CiX or CTX, it's handled via the System Administration Program or Personal Programming Interface.
Change name on display
U need to have network emanager installed on a computer
DKT 3010 SD programming mode?
If the phone is on any Toshiba DK system, enter programming mode my pressing the following sequence (without selecting an intercom line, or an outside line, but at the phone's idle state with the handset down) *#*#1*2*3
On a CIX or CTX System, again, at the phone's idle state w/ handset down dial *#*#1*2*3*
How do you set the clock on the toshiba 3010 phones
for DK series #601 n #602 or 601 n 602 but must at change at receipetions phone
2answers
Display name / date time
1)First tell me mob-ph-whitch company.2)mob-ph-Model-no-otherwise donot solve.
16helpful
6answers
Mode
Scroll
Hold
Hold (again)
I NEED TO CHANGE THE NAME ON THE WINDOW OF THE PHONE
wat system using?
find out the adminstrator phone (pic to set the speed dial)
must hv displayed phone.
press MODE will see PHONE NAME press HOLD display show ID DN it means key in extention number, after that key in name, press HOLD to confirm, repeat step for other extention name
press MODE untill time appear
8helpful
Need to reset time and name info on display for DKT301C-SD
To change time:
Press Intercom
press #
dial 652
enter 6 digit time in 24 hour format HHMMSS
press# press spkr
not sure how to fix name
Top Toshiba Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
