Red oil light flashing, oil change no problem but light still flashing noise coming from tappets are they related I have a problem on my vw jetta ? flashing light on my dash
I changed the oil censor on the head, and found that there is a another censor above the oil filter unit.I changed the oil censor on the head, and found that there is a another censor above the oil filter unit.
You can't post conmments that contain an email address.
clean the pollen filter ,as for engine then change the oil for a detergent oil and also put a couple of squirts of washing up liquid in with the oil as well and run it around for a week then the hydraulic tappet noise should stop then make sure you change the oil every 6000miles with a oil filter every third oil change ,your oil has beeen left too long and its gummed up the hydraulic tappets
Are you using the specified grade of oil and oil filter? I know some some Volkswagens are really picky when it comes to the oil and won't like anything other than from the Volkswagen Dealership
you will have to check your oil pressure with an oil pressure gauge. it could be a problem with your oil pump ( or a blocked gauze on the oil pump) and the tappets noise is related to the oil pressure.
There's no tappets adjustment needed for this engine as they are hydraulic lifters. Try using 10w40 instead and see what happens or otherwise try using Moreys oil treatment with your current oil as it seems to me that the noise is more at startup and for a short period. Cheers.
This usually indicates that the oil pressure is low, but you need to get it checked out whether it's just a pressure sensor fault or connection issue, or it actually has got low oil pressure. The last one is the most concerning, because it could be causing internal damage if there is not enough oil pressure. Hopefully with a relatively late model car it will just be a sensor issue, but I would get it checked out ASAP, and preferably not use the car in the meantime.
Hope this helps,
Mark.
Can it be that i have a electrical problem?
