Question about Maytag EPIC MFW9600S
Control lock stays on
Control lock light stays on machine will not start i tried unplugging the machine still no result
Posted by eddyo on
RonW
    Scholar:
    New Friend:
  • 111 Answers
Try holding for 3-5 seconds should unlock controls.
Posted on Jan 24, 2014
2 Related Answers
Anonymous
  • 331 Answers
SOURCE: Maytag front load 9700
First things first... please follow this link to see if your machine is part of Maytag's recall... http://www.washerrecall.com/ or this site for details on the recall... http://www.cpsc.gov/cpscpub/prerel/prhtml07/07135.html
Posted on Aug 19, 2007
Kevin White
  • 1902 Answers
SOURCE: control locked light on - machine will not
Hello
To unlock the controls press and hold the END OF CYCLE button for 15 seconds, the problem should be resolved after doing this. Please get back to me if you have any other questions.
Kevin
Posted on Nov 15, 2010
Testimonial: "This WORKED! I was just about to call a repair man. This probably saved me at least $100"
1helpful
Why the lid locking led is blinking after lock the lid and stay standby with out working ?
The unit will not operate in this condition until the lid lock signals a locked condition. The controller is signaling that it believes the lid is not locked. Assuming the lid is actually locked, then this might occur because of a bad wiring connection (check the lid lock switch assembly and the cabling at the controller) or a bad lid lock switch/sensor.
tip
The front light lit on my Whirlpool dryer is showing control locked
Hi.
If the front light lit is control locked, that means that your Whirlpool electric dryer had been set in control lock mode.
Control lock is a special mode that will prevent user from changing settings or using control until the dryer gets unlocked again.
The machine is set to control lock mode by holding down the CONTROL LOCK/UNLOCK button for several seconds. In the same way you can stop the control lock mode when the machine is already set to Control Lock.
When the dryer is running and Control Locked is on, the dryer can still be stopped by pressing the Pause/Cancel button, but cannot be restarted until the control is unlocked.
If the front light lit is control locked but the dryer door opens and it does not turn off, then you are probably in this situation. In that case, the door will be opening , but the machine still stays locked.
Disconnecting the machine from power, either unplugging power cord or tripping circuit breaker, won't help. The control lock system is designed to stay on in case of power failure.
If the machine is control locked, try unlocking it with the following procedure.
To unlock: Press and hold the CONTROL LOCK/UNLOCK button for 3 to 5 seconds to turn the control lock feature off.
If that does not work, try disconnecting power for five minutes to reset the machine, and eventually do unlock again. As said, cutting power alone will not cause the machine to unlock.
If the machine is still not responding, the lights stay on all the time, the dryer panel does not respond to control unlock procedure, and the door does not lock anymore, then it may be a defective control board.
If you are in this situation, before replacing the control board more parts, including the door lock must be tested. In that case the best option may be contacting the Whirlpool support number listed on the Dryer use and care manual, usually in the last pages.
In this case try resetting control lock as explained above, as told the dryer is more likely control locked and then stopped.
Regards.
Ginko.
2answers
How to correct control locked will not go off on whirlpool ghw9150 washer
While the machine is 'on' press & hold the "end of cycle" button for 3 seconds, or till the lock light goes off. This is on the far left or right of the machine's panel. Good luck! Pl rate me.
Kenmore HE Washer Model 11046472501 - add a garment light stays on with the door lock light on at the same time. We have unplugged the machine and ran the drain and spin mode, but he washer won't
Not sure if these will help or not:
http://www.youtube.com/results?search_query=Kenmore+HE+Washer+diagnostics&oq=Kenmore+HE+Washer+diagnostics&gs_l=youtube.12...4054.11443.0.13769.12.12.0.0.0.0.236.2449.1j0j11.12.0...0.0...1ac.1.93rgz26enSw
Door won't open. door locked light stays on. I
Press and hold the End of Cycle Signal button for three seconds. This will turn off the Control Lock feature.
Thank you !!
Control lock light stays on nothing else happens what could i do
Those locks are on a timer that until the wash is complete it does not unlock the unit.
Unlike a normal washer where you can open it at any time and throw in some cloths you may have forgot, this one seems to take up to to minutes after you stop the unit mid wash.
If it is taking more then the 2 minutes then the door lock may be faulty, try unplugging the unit then plugging back in, do not force the door open as this will result in a broken switch.
Good Luck!
I’m happy to help further over the phone at https://www.6ya.com/expert/michael_341f3f9dee622e54
3helpful
2answers
Control locked light come on and stay on, machine not running
take a good look and read on your control panel i don't remember which button you need to hold for 3 or 5 second to lock unlock control panel. it is also called child lock system.
Maytag EPIC MFW9600S Logo
Top Maytag Washing Machines Experts
Jessie Goss
Sheldon Dedek
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
