Question about JVC GR-D290 Mini DV Digital Camcorder
When in video recording mode LCD screen and viewfinder are black when the lens cap is off.
Haven't used my GR D290 in a long time. Charged it up and everything appears to work except recording mode. The lens cap is OFF but no images appear on either the LCD screen or through the viewfinder. The lens is clean and there are no obstructions.
Ryan Thomas
    New Friend:
  • 62 Answers
It could one of a few problems:
1. The viewfinder is pulled out and "PRIORITY" is set to "FINDER".
Push the viewfinder back in or set "PRIORITY" to "LCD".
2. The LCD monitor's brightness setting is too dark.
Adjust the brightness of the LCD monitor.
3. If the monitor is tilted upward 180 degrees, open the monitor fully.
Download the manual for more info:
JVC GR D290 Manual
Posted on Mar 18, 2015
5 Related Answers
Anonymous
SOURCE: lens cap?
I just had this problem and was going to replace the camcorder. My husband took the lens cap off, placed the camera in the sun for about an hour then flicked (not banged or beat - just a light tapping) and now its working. He said condensation, dust, lack of use, etc may have made the lense stick. Good luck!
Posted on Aug 17, 2008
aditniyee
aditya pratama
  • 3 Answers
SOURCE: Lens Cap Is On
ccd image sensor  your camcoder has broken
Posted on Sep 04, 2008
zohail
Shoaib Rais
  • 1223 Answers
SOURCE: no view
CCD failure u r lucky that u can get it repaired free of charge see the link below for details
http://www.jvc.co.uk/template.php?page=100102
just contact JVC authorised service centre in ur area and get it repaired free of charge it is a manyfacturing fault and this letter is valid thru out the world dont worry
Pls rate me FIXYA for help
Posted on Mar 20, 2009
satavlad
Alex Zoubkov
  • 405 Answers
SOURCE: GR-D71, no longer records images
CCD (imaging chip) went bad and require replacement. Not a very expensive repair, but has to be done by professional.
Posted on Nov 05, 2009
Rick Riggins
Rick J Riggins
  • 1812 Answers
SOURCE: Only the audio is recording, NO VIDEO, onto the
This is usually caused by a defective CCD image sensor and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Jul 22, 2011
My JVC GR - D290 says that the lens cap is on when the lens cap is off
Open and close it a few times. Maybe tap the side a little bit as the lens cap switch may be sticking.
JVC GR D290 Manual
Jan 06, 2013 | JVC GR-SXM260E Camcorder
No view
Mar 19, 2009 | JVC GR-D50 Mini DV Digital Camcorder
No visual through LCD or viewfinder
This is a Iris Problem .....THe Best in house solution is to Bang the camera Lightly with your palm .... other wise send it to a repairman .... coz you wont be able to open the camera to such an extent
Oct 14, 2008 | JVC GR-SXM260U Camcorder
No view on viewfinder or screen
If the lcd screen is black even with the lens cap off,the ccd base assy. needs replacing.
May 28, 2008 | JVC GR-D20EK Camcorder
Cannot record anything - can't see anything thro the viewfinder or in the screen
Hello grnca,
CCD Imager ( an electronic part) at the end of Lens Assy got defective thats why you can't see any result in camera mode.
Please contact nearset Sony repair shop for replacement of CCD Imager IC.
May 19, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
No picture on lcd & view finder
PLease see http://www.fixya.com/support/t131881-sony_cam_recorder_wont_record for more information on this i have had the same problem, faulty CCD image processor chip.
Apr 01, 2008 | Video Cameras
JVC Digital Video Camera GR-DVL107E
Assuming you don't see any video through the viewfinder, it could be that the CCD has died on that camcorder. It happens, though not frequently.
If the video though the viewfinder is clear, there might be some sensor on the lens ring to indicate a lens cap, or an automatic lens cap not properly disengaging when put in record mode.
Jan 20, 2008 | Video Cameras
Recording problem
Knowledge Article C116445
There is no picture or a black screen appears in the viewfinder or LCD when attempting to record. Follow this procedure to troubleshoot if there is no picture or a black screen appears in the viewfinder or LCD when attempting to record. NOTES:
  • Because each of these steps represents a possible solution to this issue, check the viewfinder or LCD status after completing each step.
  • It may be necessary to refer to the operating instructions provided with the camcorder for information on how to perform a task on your specific model.
  1. Ensure the lens cap on the front of the camcorder has been removed.
  2. Ensure a fully-charged battery is inserted in the camcorder.
  3. Ensure the STANDBY/LOCK switch is set to the STANDBY position.
  4. Turn on the camcorder and set it to the CAMERA mode.
  5. Look to see if an image can be seen in the viewfinder or LCD.
  6. IMPORTANT: Some camcorders have both a viewfinder and LCD. To conserve power, the viewfinder and LCD will not display at the same time. To use the viewfinder, the LCD must be closed.
  7. If the issue is not resolved, reset the camcorder to factory specifications.
NOTE: If the issue is still unresolved after completing the troubleshootin
Nov 30, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
Black lines in play mode
this sometime appears when the camera hasn't been used, this dissappears after sometime of playing.
Nov 18, 2006 | JVC GR-D290 Mini DV Digital Camcorder
JVC GR-D290 Mini DV Digital Camcorder Logo
279 people viewed this question
Top JVC Video Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
