Question about Bunn GR10 Coffee Maker
Warmer plate replace warmer plate
My warmer plate light does not work and the water in holding tank feels warm on top not on bottom,coffee is not hot enough to dissolve powderewd creamer.Why?
No warmer plate llight:
Usually means bad switch. Bunn Part no. is 20316.0001. Replacement available at link below.
Bunn Home On Off Warmer Control Switch Lighted
Note differences in switch wiring in photo below between old and new style switches.
Coffee not hot:
Make sure "Vacation Switch" is in OFF position.
Aug 07, 2014 | Retail Supplies
Brewed coffee overflowed on to warmer plate. Now water does not heat and flow and warmer plate does not heat up.
Unless it is an expensive brewer, get a new one. The brewer needs the bottom plate to heat in order for it to work at all. Should be imune getting wet though, but sounds like bad heating element.
If you need further help, reach me via phone at https://www.6ya.com/expert/steve_24d988f3507f7480
Oct 11, 2013 | Cuisinart Model DGB-550 Coffeemaker...
Someone recommended this, but I don't understand why do I need the plate warmer?
You don't have to have it, but it adds something to the hosting environment. It helps keep food warm longer on the plate, and it's especially helpful for things like pasta that tend to get cold quickly.
Apr 22, 2013 | Retail Supplies
Every time we turn on the glass plate warmer, there is a "pop" sound and the circuit breaker trips in the outside fuse box.
The glass plate warmer element is faulty and short circuits every time you turn it on. The 'pop' you hear is the active short circuiting to earth. It needs replacing.
Mar 02, 2011 | Falcon Kitchen Ranges
Bottom heat plate is not hot enough
Warmer element may have dropped.Remove 3 screws and check.There are two nuts that fasten warmer to plate.
Jan 04, 2011 | Bunn VPR Coffee Maker
Need warming plate for Bunn Pour O Matic coffee pot
Due to UL regulations, warmer plates can't be sent out. However, you warmer plate can be repaired for a minimal charge. Please call customer service with the model and date code and we will be happy to provide you with the cost and address.
Nov 26, 2009 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Faulty plate warmer on rangemaster 110 dual fuel
We have the same problem on a Rangemaster Toledo 110. It is not a fuse.
The 'Hot' light still comes on because that is a different (parallel) circuit.
Examination by a competent electrician has found that the soldering for the wires that power the warming metal strip under the glass is faulty. You will have to ask for a replacement part.
There may be a design flaw, so you might want to enquire about the professional all gas burner top and just use the griddle as a warming plate over the second wok burner.
Good luck.
Jan 20, 2008 | Rangemaster Classic 110 (Dual Fuel) Dual...
Bunn GR10 Coffee Maker Logo
55 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
gbob59
Marvin
Marvin
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
