SOURCE: dont know how to use coffee maker
Hi this is tech crazy
The above link u will get the whereabouts of a coffeemaker and its usage
http://home.howstuffworks.com/coffee-maker3.htm
Kindly do rate me on the above said solution
SOURCE: Can't find my BUNN NHBX-B manual...can I find it
I work for BUNN. Here's a link to the manual for your NHBX-B
http://www.bunn.com/pdfs/retail/usecare/41756.0000_STX_NBX_U_C_English.pdf
SOURCE: No manual with Bunn NHBX coffee maker.
Leave the unit unplugged and add a carafe of water to the top reservoir.
Close the lid.
Wait a bit to make sure the water has drained into the tank.
Add another carafe of water to the top reservoir.
Place carafe on warmer plate.
Close the lid.
When water stops going into the carafe, you may plug the machine in and make sure the "travel switch" is in the ON position. ON = |, OFF = O.
Wait at least 15 minutes for the water in the tank to heat up, and brew as you normally would for other BUNN coffee makers.
SOURCE: I have a bunn coffee maker the NHBX is the # it is
Please give Customer Service a call with the model and date code. If the machine is 3 years old or less, it will be replaced with a new machine. If it is older than 3 years, it can be exchanged for a reduced price.
If you will locate the date code on the bottom of the unit and then call Customer Service, the machine will be replaced at no cost or if over 3 years old, at a reduced price.
