Question about Freezers
Defy f640 wiring diagram - Freezers
Posted by paul pirzenthal on
John Moult
Defy F640 freezer fan keeps switching on and off and does not cool.
Posted on Aug 18, 2014
Defy 130L chest freezer wiring diagram
Do a google search for a wiring diagram for your model
Nov 05, 2017 | Freezers
What is the horse power of the F350 defy upright freezer
That info. is stamped on the product information tag usually found on a sticky tag or riveted to the frame up front.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Oct 25, 2017 | Freezers
Defy 350lt upright freezer red alarm light flashing the light start flashing and the food started defrosting
Check for proper door closure or internal light function first
Next, check temp. control settings. If all checks ok, call a tech. to fix it
Sep 21, 2017 | Freezers
Hi.. I have a defy upright freezer.. it is currently displaying an error "c2 !". Defy say this is because of the change in outside temp. Is this true, how long is it supposed to last? Many thanks.
If unit is not in a controlled environment yes temp will be confused and will take 24 hour to correct but if outside temp is changed it will do again and again all units designed for controlled temp room not outside in garage or out buildings with no heat or cooling controled room
Feb 28, 2017 | Freezers
Defy Freezer F350 red alarm . What can cause it to alarm.
door not sealing properly check for fold or door alignment
Feb 22, 2017 | Freezers
DEFY C361 Double door fridge that does'nt get cold
We solved this by replacing the thermostat with a new one.
Sep 11, 2009 | Freezers
WIRING DIAGRAM FOR MODEL 6125-S SERIAL 87-T[DIE]
here's a service and installation manual online click here it has a wiring diagram. good luck
Jan 03, 2008 | Delfield Freezer 6125XL-S
Freezers Logo
Top Freezers Experts
Dennis Boxerman
Dan Webster
Dan Webster
Are you a Freezer Expert? Answer questions, earn points and help others
