Question about Steca SOLSUM 10.10F 10A 12/24V Charge Controller
Red info led on steca solsum flashes quickly and unit will not charge from solar panel. This occurred when I attached the solar panel.
Posted by Ian McEwan on
  • Ian McEwan
    Ian McEwan Jan 21, 2014
    Unit had reset. Recalibration needed to be done and it is now working again.
  • MIRAR Zakaria
    MIRAR Zakaria Mar 16, 2014
    would you give more explanation,I had the same problem
Geo Oberholzer
  • 0 Answers
I also have this problem, can you please explain how to reset the controller?
Posted on Dec 30, 2014
Can I connect my UPS with my battery which is connected to a solar on the roof? what will the voltage output to appliances?
The UPS has a stated output, that does not change. It is most likely 115vAC. If the UPS does not have enough charge, it will warn you. If you are asking if you can connect your solar direct, no, do not! The UPS is not a charge controller or regulator which is what I think you are asking. Summary: Solar to UPS to appliance is ok. If you exceed the amperage of the UPS, again, an alarm will sound or not work at all. for instance, you will not power a microwave this way.
Aug 01, 2016 | Apollo 1650ETL Swing Gate Motor 20 Watt...
Panasonic TX-L42E5B blinks 3 times which board is faulty
When an abnormality has occurred to the unit, the protection circuits operate and set the unit to stand by mode. At this
time the defective block can be identified by the number of blinks of the Power LED on the front panel of the unit.
Fault maybe on the A board 3.3V SOS give me your email & i send you the full timing chart.
Apr 04, 2016 | Panasonic VIERA TX-L42E5B 42" LED TV...
There is a blinking red light next to power button.Panasonic tv will not turn on.
1. Subject
Information of LED Flashing timing chart.
2. Contents
When an abnormality has occurred the unit, the protection circuit operates and reset to the stand by mode. At this time, the
Hopefully it eventually stops blinking after unplugging set from the outlet, otherwise claim your Nobel Prize for wireless energy transmission.
Oct 17, 2014 | Panasonic Viera TH-50PZ80U Plasma TV
My Denon DM39 that I purchaed yesterday keeps powering off and then a red light flashes. Coudl it be related to my solar power?
Sounds like you system is set up to only provide output current when not charging via the array... its common... shut off or disconnect panels and your problem is solved but the batteries won't be receiving any charge obviously... this set up is used when the systemhas nothing to limit or control the current produced from the arrays/panels from going directly to the attached output devices. This is typical in small pv systems.
Dec 30, 2013 | Denon DM38S Audio Shelf System
Midland btx2
The red LED on the unit will start flashing when charging begins.
Allow the headset to charge until the unit stops flashing or the blue LED turns on.
When the charge is complete (the red LED is not flashing), release the headset
from the charger
Jul 30, 2012 | Radio Communications
Hello I have a 1994 maxima manual transmision,it have a check engine light on,when I start the car and beguin to drive it,runs perfect the a few minutes later the car gets very lazy almost want to turn...
Hello! I'll need the trouble code to fix your vehicle...Below is procedure with a code list...Guru...saailer
Remove the trim panels in front of the center console. Locate the engine computer attached to a floor-mounted bracket on the transmission tunnel between the console and the firewall.
  • Turn the diagnostic mode selector, located in a round opening on the side of the engine computer, until it stops. Observe the small red and green LED lights on the side of the computer next to the mode selector. They will flash to indicate the modes, with a pause between each mode. One quick flash is mode one, two quick flashes is mode two and so on. When the light flashes indicate mode three, quickly turn the mode selector counterclockwise until it stops. You have entered mode three diagnostics.
  • Remove the trim panels in front of the center console. Locate the engine computer attached to a floor-mounted bracket on the transmission tunnel between the console and the firewall.
  • Turn the diagnostic mode selector, located in a round opening on the side of the engine computer, until it stops. Observe the small red and green LED lights on the side of the computer next to the mode selector. They will flash to indicate the modes, with a pause between each mode. One quick flash is mode one, two quick flashes is mode two and so on. When the light flashes indicate mode three, quickly turn the mode selector counterclockwise until it stops. You have entered mode three diagnostics.Observe the red and green LED lights on the side of the computer. The red light flashes to indicate the "Tens" digit of the code and the green light flashes to indicate the "Ones" digit of the code. For example, if the red light flashes two times and the green light flashes seven times, this would indicate code 27.
    Turn the ignition key off for two minutes to exit diagnostics. The computer will automatically return to mode one for normal operation...
    Code 11 Crank sensor angle
    Code 12 Mass airflow sensor
    Code 13 Engine coolant temperature sensor
    Code 14 Vehicle speed sensor
    Code 21 No ignition reference
    Code 22 Fuel pump
    Code 31 Engine control unit
    Code 32 EGR sensor
    Code 33 Oxygen sensor
    Code 34 Knock sensor
    Code 35 EGR temperature sensor
    Code 43 Throttle position sensor
    Code 45 Injector leak
    Code 51 Injector circuit
    Code 54 Automatic transmission signal
    Code 55 No malfunction recorded
    I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
    May 04, 2012 | 1994 Nissan Maxima
    Outdoor umbrella with solar leds with switch, doesn't turn on
    If you connect to solar panel for the lights to go on do the lights go out at night? If so, and the they do not light when hooked to the batteries then the batteries may have no charge and may also not be holding a charge. Put in new batteries to test.
    Apr 26, 2010 | Solar 2-wire Pull Chain Light Switch For...
    Power indicatoror
    From the manual:
    "Attach the barrel tip of the AC Charging Adapter to the AC Charging port of the POWER TO GO® and plug the standard two-prong plug into an appropriate, functioning 120 volt AC outlet. The red Battery Status LED indicator will flash, indicating a proper connection has been made and the unit is charging. The green Battery Status LED indicators will gradually light as the charge level rises. The POWER TO GO® must be charged for approximately 11-17 hours prior to first use. All Battery Status LED indicators will be lit solid (the red indicator will stop flashing) when the unit is fully charged.
    Aug 29, 2008 | Black & Decker Power To Go Cordless AC/USB...
    Steca SOLSUM 10.10F 10A 12/24V Charge Controller Logo
    1,483 people viewed this question
    Top Steca Renewable Energy Experts
    Marvin
    Marvin
    Vernon Taylor
    john h
    Are you a Steca Renewable Energy Expert? Answer questions, earn points and help others
