Question about Kenmore HE2 Plus Front Load Washer
Leaking door I have water inside the door where the plastic is and it drips from the bottom. How can I fix it?
Posted by Shanna Herrick on
STEVEN NEUNHOFFER
    Scholar:
    New Friend:
  • 187 Answers
Either replace the rubber seal or the entire door
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
Posted on Jan 20, 2014
5 Related Answers
mbertexas
  • 11 Answers
SOURCE: Water leaking from bottom of door during wash cycle
I had a similar problem.  It turned out to be the overflow "sock".  It's a long plastic bag that hangs from the side of the tub.  You have to get the top open, and it will be on the left side.  Where it attaches to the tub, the plastic attachment has a rubber washer that gets flattened out after time allowing the attachment to get loose and leak.  Since I couldn't find the washer to replace it, I cut a piece of gasket material like you get from an auto parts place and placed it behind the foam washer.  This made the connection tight, and the leak stopped, thank God.
Posted on Oct 23, 2007
jyackle5
Jyackle5
  • 8197 Answers
SOURCE: Kenmore Elite Front load washer leaking
You need to replace the rubber gasket around the door.
Posted on Dec 17, 2008
Arjun Komath
  • 1170 Answers
SOURCE: My Kenmore top loading washing machine is leaking
This symptom usually indicates that you have a failed inlet solenoid water valve assembly. Completely unplug the washer from the electrical supply and see if the water stops filling. If it does, then you likely have a control board failure. This is rare but possible. If the water continues to fill with the washer unplugged from electricity, I recommend shutting off the hot and cold water supply faucets behind the washer. It is likely that the water will stop filling the washer. This would indicate that you have a failed water valve assembly.
Posted on Jul 11, 2009
honeymokey
honeymokey
  • 3113 Answers
SOURCE: Our Kenmore top loader is leaking from the bottom.
This should help you. http://www.youtube.com/watch?v=ee_FoNQlSog
Posted on Apr 10, 2011
danny Hendrickson
  • 2468 Answers
SOURCE: 1 gallon of water leaks out the bottom (overflow?) dripper with every load.
your pump seals are bad,this is a cover to keep the pump dry if something up above leaked,but from the pics it looks to be the pump especially with all the water leaking,just replace the pump unit
Posted on May 06, 2012
Testimonial: "thanks. replacing the pump looks straightforward."
Rusty water dripping on the inside of the door after rinse cycle
Pull the screws out of the door check to see if they are rusted run the machine the outer door panel off should be easier to find the leak
Mar 30, 2014 | KitchenAid Dishwashers
Mazda Bt50 cab leaks on drivers side
I recently purchased a 2008 BT50 dual cab then 2 days later we had 500mm of rain and of course it leaked :( I had about 80mm of water on the drivers side floor and 30mm on the passenger side floor. I stripped the interior out of the car and started hosing the outside and watching where it was coming in. I took all the windscreen surrounds off and the cowl panel off below the screen there was no water coming in from that area. I had taken the gutter seals off but left the door seals on so the water was running down around the outside of the seals (with the door shut) and out at the bottom. From inside near the drivers side kick panel I could see water coming through seams in the metal work and when I took the door seal rubber off the body on the car I could see water was getting in at the top of the door seal rubber going down the front inside edge of the rubber and getting in through the seam where the rubber push's onto the body of the car (first problem). I took all the door seal rubbers off and run a bead of non corrosive silicon inside the cavity and pushed them back on. It seemed to have fixed the problem I dried the carpet and put it back together..Two weeks later we got another 325mm of rain and it leaked again :( not near as bad this time. Looking at the bottom of the door where the door trim meets the door I could see water coming from behind the trim and then into the car. I took the door trims off and could see water gets in when the window is up (all cars do) and is supposed to run out the drain holes in the bottom of the door but the water was dripping and splashing up to the back side of the door trim against the sheet of plastic that is supposed to seal against the door with the black mastic (it doesn't) and running straight into the car. I cut some plastic and siliconed them onto each opening on the inside of the door frame and then put the factory piece of plastic on as well (properley this time) as a backup.
So far so good.
May 26, 2012 | Mazda BT50 Cars & Trucks
My Amana french door/bottom freezer is leaking water. Did the procedure with hot water the drain in back of the freezer, although it seemed clear of ice. That didn't help. The leaking stops when I...
Two possibilities:
1. A cracked plastic tube. These will leak whenever there's a call for water - either the chilled water dispenser, or re-filling the icemaker tray (two seperate tubes). Pay particular attention to anywhere the tubes are clamped to the chassis; anywhere they're routed near or under the refrigeration unit; and near the solenoid valve - especially if there's a tight loop in the tube there.
2. A bad (leaking) connection where one of the tubes exits the water valve. Again, these will leak whenever the valve is activated.
Those plastic tubes don't last forever. I've replaced many of them for the same symptoms. They're known to simply deteriorate with age.
Manuf's make good money selling replacement tubing kits.
Aug 15, 2011 | Amana AFB2534DE Bottom Freezer French Door...
Water dripping from front left side of dishwasher
feel the botom of the door is it leaking from a plastic tube on the left between the door shell,if ti is you need a vent ***. good luck!
ERIC
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 26, 2010 | LG Dishwashers
Kitchenaid dish washer kuds24sewh4 door leaks but does not seam to be gasket ! water drips from inside of door bottom? possibly rinse aid leaking in door?
remove the inner door panel and ck for leakage . there should be water tracks . / there is a bottom seal. that may be failing / ch to see if its in proper possion .. its on the tank under the door / open the door all the way and look from inside to see. ( with a light .. mm
Dec 12, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Refrigerator leaking water
This sounds like the water line from the icemaker and the cool water reservior inside the refridgerator side. The line is a rigid plastic hose and could be a leak at one point that is small enough to allow water to run along the line. Also sounds like you have a humidity problem. Check the door seals and wipe them off and apply a thin coat of die-electric grease to the seal. this will help keep it pliable and soft.
The water in the bottom leaks into a trough that is made into the fridge. This usaully evaporates, This is for the auto-defrost. It keeps the water from getting on the floor.
Check to see if the outer door gets hot at the edges. If not, It may not be auto-defrosting.
I would first check the water line first as this seems to be a more serious issue right now. The line is probably loose at one of the connections between the ice maker and water reservior.
Jun 14, 2009 | Maytag MSD2456G Side by Side Refrigerator
WHIRLPOOL MODEL NO. ET8CHMXKBO4: WATER COLLECTING ON THE BOTTOM OF THE FRIDGE AND LEAKING TO FLOOR AT FRONT DOOR; ICEMAKER NOT CONNECTED. NO WATER IN DRIP PAN. DEFROSTER LEAKING SOMEWHERE BETWEEN...
The likely problem is the drain leading from freezer to bottom of refrigerator is clogged or stopped up. I will send you to another link so you can see and get pictures and answers to help you solve this.
http://appliancejunk.com/forums/index.php?topic=22.0
http://servicepartstec.blogspot.com/
Let me know if this help, Sea Breeze
Apr 24, 2009 | Refrigerators
Side by side leaks out front door on freezer side
try checking the tube that water drains out , it could be plugged with crumbs or old partials of food and causing the problem, This has happened with my fridge at one time , affecting the defrost cycle of the freezer and dripping water out of the door, The tube was located under the crisper in the back of the inside of my fridge, Hope this solves your problem
Apr 19, 2009 | Kenmore Refrigerators
GE Side by Side, water leak inside freezer door
you will need to [possibly replace the solinoid valves on the backdside of the refrigerator
Jan 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore HE2 Plus Front Load Washer Logo
Michael Thomas
Michael Thomas
Paul Carew
Lawrence Oravetz
