Question about Apple MacBook Pro Laptop Computer with Intel Duo Core 15.4 Inch PC Notebook
Macbook stuck on load up screen
Cant get past load up screen not even in safe mode
Dan Walker
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 47 Answers
When you say "load up screen", I assume you mean the Apple boot screen (it has the apple on a gray background).
You might try resetting the PRAM on the macbook.
You can do this by pressing and holding the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
So, turn the macbook completely off. Turn it on and immediately press and hold the Command-Option-P-R keys until the computer reboots and chimes. Once it chimes, release the keys. Your system should boot normally.
Posted on Apr 20, 2014
Toshiba satellite problems L775 can't get past "windows is loading files"
First restart your computer and then press and hold F8 keys until you get Advanced Options menu screen.Use the arrow key to highlight Safe Mode, and then press Enter, your computer will boot automatically to safe mode.
If you able to start in safe mode then update your graphic drivers from the manufacturer site
Let me know if it helps you.
Use system utility tool like RegInOut to remove unwanted files , fix registry and windows errors which causing black screen
Jul 03, 2013 | Computers & Internet
Cant get past microsoft windows loading bar
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Feb 26, 2010 | Toshiba Satellite L355D-S7809 Notebook
Wont get past Microsoft Windows XP loading screen on Acer Aspire1
Feb 17, 2010 | Acer Aspire One AOA150-1126 Notebook
Won't boot past the XP screen
go to bios and select boot option first boot cdrom,
i think f12 press then select boot order, if still cant dvd rom or rw, maybe week,
thanks
Oct 09, 2009 | Compaq Presario 700 470024-192 Notebook
Im having the exact same problem doesnt load past welcome screen!
Try to login in the Administrator account, press Ctrl+Alt+Del (2 or 3 times) in the welcome screen and you'll get a login square, in username name type Administrator and password leave it blank if it logins without a password go to control panel and create new accounts.
Jun 15, 2009 | Dell Microsoft Windows XP Home Edition
Cant get past error even tryed to repair windows or how can i install reinstall
Try booting into safe mode by pressing F8 when boot up starts. Choose safe mode. When it's booted up, right click on "my Computer" and choose properties. Click on advanced and choose the advanced tab. Go to performance and change the settings of Virtual Memory to what Windows Recommends.Restart.
May 29, 2009 | Gateway Essential 400 PC Desktop
Blank screen
Have you tried starting in the 'Safe Mode?'
If not, either F5 or F8 (right after anything  appears on the screen) will bring up a short menu to allow you to choose the boot mode; choose the Safe Mode. This loads only the most basic windows files and will let you do some fundamental checking of the hard drive and Win installation.
If you can get that far, Click on 'Start,' then 'Run' and enter 'rstrui' and OK. This should start the Restore routine.
If it does, choose 'Restore to an earlier date.' Hopefully you have had Restore turned on and then you will have a calendar with light and bold dates. Choose a date a few days in the past and let it run.
This may or may not put you back in operation.
Jan 11, 2009 | Acer Aspire 5315 Notebook
Inspiron B130 won't boot
plz try to boot through safe mode, if you can then log in normally.
if you cant boot from safe mode then you have to reload or repair your os.
Dec 23, 2008 | Dell Inspiron B130 Notebook
Unable to get past the blue screen
boot on safe mode and remove the program you have recently installed
Apr 08, 2008 | Compaq Presario 5000 PC Desktop
Apple MacBook Pro Laptop Computer with Intel Duo Core 15.4 Inch PC Notebook Logo
120 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Ekse
Jeffrey Groves
Jeffrey Groves
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
