Question about GE GSH22JFR Side by Side Refrigerator
What is % medical strenght hydrogen peroxide
Handles are yellowed
Posted by Robert Johnston on
Bruce
    Sergeant:
  • 311 Answers
The better "solution" is Westley's Bleech-White White Wall Tire Cleaner. Available at WalMart (or most any Auto Supply store) for about $7 for a 1/2 gallon or so.
Is great stuff.
Will clean all sorts of plastics, white or colors, and many other surfaces, too. Works great in and on plastic picnic coolers, especially - freshens them up and removes the stains.
Be careful with it, it is a bit caustic. If you are hyper-sensitive to chemicals, use rubber gloves and open a door for a bit of fresh air when you use it.
Posted on Jan 31, 2014
Is hydrogen peroxide dangerous for diabetics to use?
Hydrogen Peroxide. This first-aid staple has been promoted as a way to help your body manage oxygen better and fight a variety of ills. Improved management of blood sugar levels is one of the claims associated with hydrogen peroxide. However drinking this substance could damage your digestive tract. Nov 6, 2017
Jan 01, 2018 | Water Heaters
Tip
How do I Clean iPod Ear buds
<p>IPod ear buds can get grungy from regular use and should be cleaned and disinfected frequently. If your iPod headphones with others, there is potential for the transmission of germs and infections. Be sure to immediately disinfect your earplugs if someone uses them. <br /> <p><br /> <p>Soap and water clean <br /> <p>1. Disconnect the headphones from the iPod. <br /> <p><br /> <p>2. Mix a mild soap with warm water. Dampen lint-free cotton with soap and water mixture. Wipe the earphones with a damp cloth. Do not get water into the holes. <br /> <p><br /> <p>3. Enter the cloth under warm running water. Rinse to remove all soap. Twist the cloth to dry. Wipe the earphones to eliminate soap residue. <br /> <p><br /> <p>4. Rub a clean, dry cloth over the headphones to dry them. <br /> <p><br /> <p>Disinfection with hydrogen peroxide <br /> <p>1. Buy a solution of hydrogen peroxide 3% or disinfectant wipes. This product is available in pharmacies and supermarkets. <br /> <p><br /> <p>2. Dampen a clean lint-free cloth to clean the peroxide and the headphones. <br /> <p><br /> <p>3. Wipes clean with a pre-designed for cleaning hearing aids if you do not feel comfortable using a solution of hydrogen peroxide. These scarves are not guaranteed damage plastic, silicone or rubber. <br /> <p><br /> <p>4. Carefully wipe the headphones with a clean, lint-free. <br />
on Aug 09, 2011 | Apple iPod touch
Can adding hydrogen peroxide to gas tank eliminate o2 sensor alarm
I wouldn't add anything like hydrogen peroxide to the gas tank, unless you want to destroy the engine. Why not replace the sensor?
Feb 20, 2015 | 1998 Ford Ranger SuperCab
What affect does taking 35% food based hydrogen peroxide has ?
Don\'t drink it.
Small amounts used for mouth wash occasionally are okay when spit out.
Cleaning water heater with hydrogen peroxide is fine... because H2O2 is not poison outright.
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Nov 01, 2014 | Water Heaters
Which type of gel is used for teeth whitening?
If you really want to know about the Gel that is used in whitening of teeth than you may have to visit. http://www.pearlywhitescenter.com/
May 02, 2013 | Discus Dental NEW Day White ACP 9.5% Teeth...
Is there a difference between whitening and bleaching teeth?
According to the FDA, whitening makes teeth be natural tooth color and bleaching whitens beyond the natural color
Apr 24, 2013 | Health & Beauty
Should I add hydrogen peroxide to my aquarium water?
In order to ensure that the water in your aquarium will be clean and to minimize their contaminants, Hydrogen Peroxide should be added to the water.
Sep 05, 2012 | 1topstore Fish
Clean a whirlpool
The yellow is caused by UV radiation (sunlight) Depending on how yellow the parts are, you can soak them in Hydrogen peroxide for a day or so. You should notice a difference after a day if it is working.
Mar 25, 2009 | Home
GE GSH22JFR Side by Side Refrigerator Logo
288 people viewed this question
Top Refrigerators Experts
gbob59
Marvin
Marvin
