I have an iphone 4s that has been giving some trouble, the screen trembles and the top of the page, also appears at the bottom, whilst sometimes has the bottom of the page also running through the middle. Its worse for pictures. last night it turned itself off and wont come back on, no matter what i try, its fully charged and i have just updated credit. please help.
SOURCE: wont turn on
Please check the charger connector for dirt, if possible take an old toothbrush and clean with alchohol, let it dry and refix everything. should work.
SOURCE: my iphone wont turn on or charge!!
That happened to me. Push the home and on/off buttons simultaneously until the apple logo appears, then wait until it has fully restored the system. This should work. Good luck
SOURCE: iphone wont turn on!!!
Hi slondon83,
I believe you will have to reflash your device, using the restore feature on iTunes and the CFU mode in you iPhone.
To restore your iPhone, you will have to enter to CFU mode:
1. turn off your phone, or wait it get turned off by itself.
2. press and hold the power button for exactly 3 seconds.
3. whithout leaving the power button, press the HOME button for another 10 seconds exactly.
4. after 10 seconds leave the power button but still, keep the HOME button pressed.
try all these steps, of course, while you iPhone is connected to your computer with the USB cable and the iTunes software is on.
you might be able to do it with this method too:
good luck!
SOURCE: phone won't turn on at all battery was fully charged when it died
just had the same problem! hold the top sleep button and the middle button for at least 10 seconds until the apple logo comes up then try start it
Testimonial: "I had tried that but I guess not long enogh so thanks for the info. Very Happy to get all my info back!"
SOURCE: my htc touch pro wont turn on after being charged all night
Had the same problem. You need new battery! (borrow from friend, if anyone has HTC to test if phone is OK with different battery).
Testimonial: "holy crsp it worked thanx:)"
