Question about Motorola Talkabout T5320 (14 Channels) 2-Way Radio
Constant static on motorol t5320 - Motorola Talkabout T5320 (14 Channels) 2-Way Radio
sadiq muhammad
    Champion:
  • Motorola Expert
  • 228 Answers
Reprogram your Radio
Posted on Jul 11, 2016
How do I unlock a Motorola talkabout
Press and hold the Menu button (the center section with the + and - buttons to the sides) until you hear a beep (3 seconds or so). After that, when you press and release the Menu button, the Channel number should flash indicating that you can change the channel. In the future, you can toggle the keypad lock by pressing and holding the Menu button.
You can find more information on the Keypad Lock feature in the manual. See page 14 and page 21. The manual is available from ManualsLib: https://www.manualslib.com/manual/106993/Motorola-Talkabout-T5320.html . For the diagram of the Motorola Talkabout T5320, see https://www.manualslib.com/manual/106993/Motorola-Talkabout-T5320.html?page=14#manual . The Keypad Lock is described here: https://www.manualslib.com/manual/106993/Motorola-Talkabout-T5320.html?page=21#manual .
I hope this helps. I usually use my Motorola Talkabout radios with the keypad lock active. I hit the various button accidentally when working in the field.
Aug 28, 2018 | Motorola Radio Communications
What's wrong when it makes constant static noise?
By constant static noise do you mean a sparking noise? If that's the case the motor may be dying.
Mar 09, 2016 | Vacuums
Constant static on talkabout t5320
Could be a sign of a bad battery. Static is a good indicator of a rechargeable battery nearing end of life.
Jan 18, 2014 | Motorola Talkabout T5320 (14 Channels)...
BellSouth 1010 walkie talkie receives constant static
you have opened up the squelch - refer to the manual to close and return radio to normal operation
Aug 27, 2009 | BellSouth Radio Communications
How do I change the channel on my T5320 2way radio?
With the radio on press the MENU button. The current channel will begin to flash. Use the + or - button to change the channel while it is flashing. Press the PTT button to lock in your selection.
Here is a link to the user guide: http://www.giantintl.com/ContentManage/manuals/Moto/T5300_T5400_User_Manual_E.pdf
Aug 04, 2009 | Motorola Talkabout T5320 (14 Channels)...
Enable GPRS for Motorol MOTOSLVRL7e for MTNL
teh best way is to call up your service provider and ask them for GPRS, they will send you the settings by SMS or on phone they will tell you.
Apr 03, 2009 | Motorola Cell Phones
Will a Motorola TalkAbout T5320 transmit to a Motorola TalkAbout T5530?
Hello Blindmaster,
Check the Continuous Tone Coded Squelch (CTCSS) settings on all the radios. (Note that some manufacturers refer to this feature as a “Privacy Code” or “Quiet Code.” The actual name of the feature may vary.) This feature encodes a low-frequency signal on your radio transmission. This signal is below the range of human hearing but can be detected by other radios. When the CTCSS feature is active your radio will ignore any signal that it receives that does not have the proper tone encoded on it.
In order for these radios to communicate, all of the radios need to be on the same channel and have the same CTCSS code programmed or the CTCSS feature must be disabled.
I suspect that CTCSS is activated on your T5530s but is not enabled on your T5320. This would result in the situation you describe.
Also take note that when using different brands / models of radios to communicate with one another that the CTCSS code numbering scheme may not necessarily be the same from radio to radio. For instance, CTCSS code “4” on the Motorola TalkAbout series actually corresponds to code “A” on the Motorola Sport models.
Best Regards,
Agent Ken
Go Ahead. Use Us.
Mar 31, 2008 | Motorola TalkAbout T5530 2-Way Radio
Motorola Talkabout T5320 (14 Channels) 2-Way Radio Logo
134 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Muntejaya Ginting
Muntejaya Ginting
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
