Computers & Internet Logo
A
Anonymous Posted on Jan 18, 2014
Cursor works for short period, then stops. The mouse in use is gear head optical.PC
All the normal actions of mouse works ok, right/left buttons. The cursor movement stops for a period, then is active again. The optical eye light is not on when the cursor stops.
Louis F Hoholek Jr
Level 3:
  • Master 1,140 Answers
  • Posted on Nov 02, 2015
Louis F Hoholek Jr
Master
Level 3:
Answers
1140
Questions
0
Helped
258716
Points
4510
5 Related Answers
Anonymous
  • 10 Answers
  • Posted on Nov 01, 2007
SOURCE: Acer Aspire 3102WLMi Sempron3200+ no keyboard or mouse activity
from ur update..it seems lik that it's not any soft based errors...it's hardware error..so it's better to hand over that to authorised service expert!!!!dont let anyone repair that!!!it will make ur problem much more bigger!!!!friend!!
MysteryFCM
Steven Burn
  • 187 Answers
  • Posted on May 26, 2008
SOURCE: drifting cursor
Drifting of the mouse pointer is a well known occurance with laptops and is not something you can "fix" (occasionally you will be lucky and the manufacturer will release a patch, but this is very rare)
Anonymous
  • 197 Answers
  • Posted on May 29, 2009
SOURCE: Erratic movement of cursor
try to re-install the driver of your touchpad. i suspected it could be the driver issue.
Anonymous
  • Posted on Jul 18, 2009
SOURCE: Touchpad has no tap, left key not working.
I had this issue and resolved it by doing the following:
-Open the start menu by using the windows button
-Use the arrow keys to highlight run and press enter
-Type 'control panel' and press enter, find the mouse properties and enter
-From the buttons tab in mouse properties, go to double click speed and change to slow and confirm the changes
-At this point it probably still wont work, so do the above again but change the double click settings to fast and confirm.
-Restart your PC and this should resolve the matter. you can alter the double click speed again if you wish :)
Hope this helps,
tbo
Anonymous
  • 615 Answers
  • Posted on Jul 30, 2009
SOURCE: no cursor activity
Dear Sir,
Generally for compaq there is lock for touch pad you can see a moving lock below or above the touch pad. If locked the tochpad button,touch pad not sensitive.So open the lock and now you can move pointer using touch pad. see this pic
http://icerazerstudios.com/wp-content/gallery/random%20images/touchpad.jpg
there is black color button lock appear at the upper border of touchpad.
When plugged into th usb port my mouse will not register as being plugged in.
hi
  1. click Start, and then use the Start Search box.
  2. Type devmgmt.msc, and then click OK. Device Manager opens.
  3. In Device Manager, click your computer so that it is highlighted.
  4. Click Action, and then click Scan for hardware changes.
  5. Check the USB device to see whether it is working.
thanks
tip
Mouse pointer with keyboard keys
<span><b>You can control your mouse pointer with keyboard keys in all windows versions. When your mouse stops working, you can enable this keyboard feature to complete your important work. This keyboard mouse can performs all tasks same like a normal mouse.</b><br /><b>Follow the given steps to activate the keyboard mouse:</b><br /><b><br />To edit this feature, first you should log onto your computer with administrative rights.<br />To activate this feature, press Alt+Shift+NumLock keys at once and you will receive a small MouseKey box.<br />To keep MouseKeys on, click on Ok button or click on cancel button to cancel MouseKeys box.<br />Click on Settings button, if you want to adjust the mouse cursor detail settings.<br />Here a new dialog box will appear with the title Settings for MouseKeys", now you can manage all mouse settings for example mouse cursor speed, acceleration and some other features.<br />Now using Numeric keypad, you can move your mouse pointer. The controls are:<br />*<br />1,2,3,4,6,7,8 and 9 keys are used to move the mouse cursor into different directions.<br />*<br />Key 5 is used as mouse click button.<br />*<br />Insert key used to hold down mouse button.<br />*<br />+ Sign used to double click on any object.<br />*<br />Delete button used to release the mouse.<br />*<br />Click on NumLock button to disable this keyboard mouse feature</b></span>
on Apr 04, 2011 • Computers & Internet
Left button does not always open link/menu box options, I have to right click to open menu box and then left click the 'open link' option, please help.
That's not abnormal; some links provide primary drop-down choices when you place your cursor on them and enable you to select a choice by left-clicking on one of the choices. Others only enable you to select certain actions by right-clicking to see a drop-down list.
6helpful
Loss of control over my mouse.
Hi Arsenal,
My Logitech cordless occasionally does the same thing. On mine it was caused by a build up of gunk over the optical sensor. Once I cleaned it, it functioned normally.
I know it doesn't make sense as far as the buttons. I'm just sharing what worked for me. Hope it works for you.
Best regards
Mike
2answers
Logitech Mouse V320 Corless Optical Mouse not working
The warrenty period is usually a year. Is there a connection button on the receiver as well? Normally you need to press the connect button on the mouse, and then on the receiver shortly there after. If you want to replace it, you might have an easier time just getting a new mouse.
2answers
Mouse stopped working, but appears ok, batteries ok, can't determine problem
Is the batteries good. If so try,
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Hope this helps. Bud
2answers
Drifting cursor
optical mouse (laser) will note work on shining surface (glass)...
PLEASE RATE ME ( FIXYA )............................
Left click of my logitech cordless optical mouse not works properly
try to set on your MOUSE, here:
start-control-panel-mouse folder
hope this can help. :)
1helpful
3answers
Hope this helps others. My mouse stopped controlling cursor but buttons worked. Problem was it would not work on a black table. Slip a piece of white paper under it and waaala! It works. I'm thinking optical mouse and dark surface might be an issue.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
