I bought a LG Blu-ray player recently, model BD-300. I also have a DVD player Sony (HDZ278). I want to control both devices with the Remote control I use for my digital TV decoder (Model Scientific Atlanta Explorer 8300HD). Remote control : UR5U-8400A (Scientific Atlanta). The problem is that I can't find the codes to program the remote control with. Can you help?
SOURCE: Black Bars on all blu ray movies
Hi icmjrtdr,
Having black bars displayed when watching a Blu-Ray disc is a common occurrence, even with a widescreen television.
You may have heard or seen aspect ratios of 4:3 or 16:9. 4:3 is the ratio of a traditional television that is nearly square. 16:9 is the ratio of most widescreen televisions currently marketed. The reason that even with a 16:9 television Blu-Ray discs are displaying black bars is that many of these discs contain footage that has not been reformatted for television. The screen in a movie theater is even wider than 16:9, and rather than trim the ends, most Blu-Ray discs maintain the entire picture.
Depending on the options available in your particular television, you may be able to find a zoom setting that trims the ends and removes the black bars. It is up to you if you would rather see black bars with the entire picture or lose a small amount of the picture on each side for a full-screen experience.
Hope this helps,
Jason,
Go Ahead. Use Us.
SOURCE: Blu-Ray player not reading Blu-Ray movie
Go to sharps website and download updated firmware version for your model, then transfer the file to the blu ray using a usb mass storage device. I had to do that to mine it would not play new blu rays and i just bought the darn thing should've come updated. Good luck!
SOURCE: LG Blu-Ray BD-370 unlock codes
To set DVD Region to “0”, download file “6000.zip” (often also called “LG6000.zip”) from here:
http://www.multi-region.net/_media/6000.zip
Save the file and then unzip and extract it to your hard drive.
Now burn the subdirectory RMTM0000 and its contents (not the text file) onto a CD-ROM (ISO format, “closed” CD-ROM).
Insert CD-ROM into the LG BD 370 P player, and when the Region Management System screen is displayed, set the Region Code to “0” using your remote. Once done, press “PAUSE” on you remote to save, and you’re done!
SOURCE: Why is it that my LG BD 360 will play most bku-ray
I have the same problem with the same movie you need to connect the bluray player to your modem and update the bluray to be able to watch newer blurays
