You need to pull out the White Reflector Sheet out then push it fully in.
[email protected]
SOURCE: AF Beam Cover for 550EX Speedlite
I broke a lens once and just went and bought a New / Used Bounce Flash that had a uneversal flash-boot. most cameras have a flash plug in to acommidate Auto Flash Modes. If You Know how to test Cameras and Adjustable 'Bounce" flashes like yours PAWN SHOPS are a PARADISE.
http://www.uscamera.com/550ex.htm i bought hot shoe foot for my 430ex. they ship international.
SOURCE: speedlite 550EX Speedlite Flash
Let the flash rest for two weeks, to discharge the cap.
Buy Energizer Lit. Batteries.
Do not touch batteries ends with fingers.
Cleans 4 batteries with an Ink Eraser.
Alexander
[email protected]
SOURCE: Canon Speedlite 580EX
Buy the 550EX, it's cheaper
Master /or Slave = 550
Slave = other
Alexander
SOURCE: Canon Speedlite 550EX
I know you probably have already fixed the problem, but in case you didn't, or just to help others with the same problem:
This morning I connected my 550 EX to my camera and had the same issue with the info on the LCD flashing incessantly.
Turned out to be the diffuser on top of the flash head, the one
you pull out, then down over the flash to soften the light.
If the diffuser is pulled out even two millimeters from its
resting position, the LCD won't stop flashing!
Just push it back in, and voila!
hope this can be of help
Lucio
http://www.uscamera.com/550ex.htm i did the same with my 430ex ordered part from url above. need to do a little soldering though.
