Question about White Sewing 1418 Mechanical Sewing Machine
How to reassemble the tension button - White Sewing 1418 Mechanical Sewing Machine
Assembling thread tension on Necchi 3101
Oops! All sewing machine diagrams/manuals are available, online. Oddly. From the late 1800's, on.
Jun 15, 2017 | Necchi Sewing Machines
How do I rebuild the upper tension mechanism for a singer sewing machine model 507?
It's far too complicated to explain on here. You need to get a service manual for your model, or find one with a similar dial. Make sure the manual covers tension dials. Getting the spring wound correctly can be a challenge. Have you checked to see the if the presser foot lever is pressing against the tension dial from the inside of the machine?
Mar 01, 2015 | Singer Sewing Machines
Reassemble Tension Assembly
Depends on the exact construction, but there will be two disks that look sort of like frisbees or dinner plates. They have to face each other, back of the plate to back of the plate, like )( and not like ().
Typical tension diagram: http://www.ismacs.net/singer_sewing_machine_company/images/singer-66-tension-assembly.jpg
Feb 03, 2014 | Kenmore Sewing Machines
Thread tension control knob parts list.
There are just so many kinds of tension control knobs. Do you have a photo or model number?
Jan 30, 2014 | Simplicity Sew Precious SWSP2 Mechanical...
How do I reassemble the tension wheel on my white sewing machine?
Go to Singerco.com click the Customer support button and click instruction manuals. White manuals are housed at Singer now. Be sure to enter your model number with a "W" before the number. Hopefully you'll see a picture that will give you a hint on how to reassemble.
Dec 04, 2012 | Sewing Machines
Need instructions on how to reassemble my tension adjuster on Kenmore model 385.1551. Please help.
If you go to www.searspartsdirect.com you can type in the model of you sewing machine and it will pull up a parts breakdown of your machine. Just look for the section that contains the tension unit. You might be able to reassemble the tension unit once you see all the parts in an exploded view.
Apr 26, 2011 | Kenmore Sewing Machines
Thread wadding up
Tension!!!! Its all about the tension! I just had this issue after loosening my tension. So tighten it - the higher the number the tighter the tension. My tension is set at 6 on a Singer 9005 and it seems to work great. By turning it down to 4 I ended up with huge loops/wads of string. Hope this helps!
Nov 03, 2007 | Brother LS-2125 Mechanical Sewing Machine
Janome Memor Craft 10001 bobbin tension
There is an adjustment on the side of the black bobbin case.
Remove the needle plate, to gain access to the case. Lift it out, noting how it is positioned! On the side of it , there are two screws, one is the adjustment screw - its the one that sits out more. To increase tension, turn it clockwise 1/8th of a turn, reassemble and test sew. (make sure the top thread tension is back to where it should be). Repeat if required. DO NOT adjust too much at a time!
Good luck
Aug 17, 2007 | Janome Memory Craft 9500 Computerized...
White Sewing 1418 Mechanical Sewing Machine Logo
146 people viewed this question
Top White Sewing Sewing Machines Experts
tsalagi152
Douglas Plant
Douglas Plant
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
