GE AccessPoint Digital KeySafe 001847 Logo
A
Anonymous Posted on Jan 18, 2014
Manual download Key won't release
Where is the inside trunk release on a 2000 vw beetle. Trunk lid will not open with key, fob, or door release.
Trunk won open even with manual release http://newbeetle.org/forums/new-beetle-convertible/54170-trunk-wont-open-even-manual-release.html there is good info here C24OF
Trunk won't open
can you access it from the back seat.? you might have to remove the bench seat and then the back rest to shine flashlight to see if indeed something is jammed in the latch.
2answers
Ignition switch won't release key when it is put in park. But when I removed switch and key tumbler, the key tumbler/cylinder releases key. Why won't the key release when it is in park?
Most newer models have a safety feature called
shift interlock. This prevents the key from being turned back
to the lock position if you forget to place the gear selector in park.
Depending on the model,
If it uses a cable, it may be sticking or needs adjusting.
If it uses an electrical solenoid. may be blown fuse or park switch.
Tap, shake, and pull up on the shifter and make sure it's in park.
Trunk won't open
Lower the back seat and crawl into the trunk and see what the latch is doing when you activate the key fob. the trunk lid will have to be open to enable any repairs. Also an emergency release cable is probably visible (yellow handle) inside the trunk and will Open the trunk lid.
2answers
1helpful
My key wont turn to off in order to remove my key from ignition while in parking
Ignition - Key Stuck In Ignition Switch/Won't Turn Bulletin No.: 06-02-35-005 Date: February 28, 2006 TECHNICAL Subject: Key Stuck in Ignition, Key Will Not Return to Off Position, Shifter Button Won't Release in Park Position (Adjust Shifter Detent Finger) Models: 2002-2005 Chevrolet Monte Carlo Condition Customers may comment on any of the following conditions: - The key is stuck in the ignition cylinder. - They cannot return the key to the off position to remove the key. - The shifter button won't release in the park position. Cause This condition may be caused by the detent finger shifting over time. This may result in mis-alignment and binding of the shift rod on the shift position guide.
WHERE YOUR SHIFTER IS YOU WILL HAVE TO TAKE IT APART ..MAYBE THE RUBBER BOOT IS IT THE WAY,OR THE SHIFT LOCK SELINOID WHENT BAD
1helpful
2answers
Inside trunk release won't open trunk on 2002 Camry. Lock will not turn with master key. Remote trunk opener will open trunk.
1. Open trunk
2. Place latch in lock position
3. Pull inside trunk release to see what isn't moving
4. If trunk key won't turn, the key may be worn out and need to be replaced
Top GE Home Security Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a GE Home Security Expert? Answer questions, earn points and help others
