Question about Kenmore 4.6 Cu. Ft. Compact Refrigerator 94683 Stainless Scratched Pictures
Refrigerator will not cool down
The refrigerator seems to run fine. I can hear the motor run and the termistat is set at coldest, but the refrigerator will not cool down at all.
Posted by Randy Mackinga on
richie46
    Top Expert:
  • Kenmore Master
  • 12,962 Answers
If the unit does not cool down at all, then you might have a refrigerant leak and be low on gas. Locate the leak, fix, and refill to manufacturer's specs.
Posted on Jan 27, 2014
1 Related Answer
mcgiveral
Al
  • 68 Answers
SOURCE: freezer has quit freezing only a little over a
Is the compressor continually running? If so then there could be a leak in the system or the compressor is damaged. If it's running then stopping, the cold control (thermostat) could be damaged.
Posted on Dec 26, 2011
Samsung RS261MDPN not cooling properly
sounds like a defrost issue defrost clock heater or limit could be bad
Jan 18, 2013 | Samsung RS261MDPN - 26 cu. ft. Side by...
Kenmore side by side, freezer section is not freezing. Ice is melting. Refrigerator side seems to be working. I do not hear any noise from refrige/freezer.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 21, 2011 | Kenmore Freezers
Mdle 21571 upright Kenmore Freezer seems to run all the time and seems warm to the touch. It is keeping cold but the running all the time doesn't seem right.
heatman101
Sep 02, 2011 | Kenmore Freezers
Our freezer seems to be running all the time. Door seems to be sealed good. Food is frozen well. What should I check?
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Apr 02, 2011 | Frigidaire Freezer 16.7 cu. ft. Upright...
Freezer motor is running temp is 30 degrees
heatman101
Mar 19, 2011 | Frigidaire 11.6 cu. ft. / 328 liter...
Power but wont run the motor to freeze
heatman101
Jan 05, 2011 | Haier 13.6 cu. ft. / 385 liter Upright...
Motor/compressor hums but does not run. is there a reset button on this unit?
If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Oct 04, 2010 | Frigidaire 9 cu. ft. / 255 liter Chest...
Freezer runs frequently, we don't open it very often but it seems to run more often then needed. Should I change the settings on the timer? How?
No timer...it goes on and off on a t-stat...if it is running alot it is not cooling properly...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
heatman101
Sep 18, 2010 | True 19 cu. ft. / 538 liter Commercial...
Refrigerator does not get cold
In your freezer section, there should be a "control" for the freezer temp. I say "control" because the knob is attached to a flap that only controls airflow the the lower section. If the knob is turned to coldest it will block almost all of the air from getting into your fresh food section.
Jun 14, 2009 | Frigidaire Freezers
Food in freezer not frozen; food in refrigerator not cold
1.check the coils on the back or under side.
2.check if compressor is running
3.check if copressor is hot
4.let me know the answers
Jan 14, 2009 | Freezers
Kenmore 4.6 Cu. Ft. Compact Refrigerator 94683 Stainless Scratched Pictures Logo
123 people viewed this question
Top Kenmore Freezers Experts
John Tripp
John Tripp
Felizardo Erilla
Felizardo Erilla
PNiss
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
