Remote Start System  Logo
A
Anonymous Posted on Oct 18, 2017
I tried to start my 2000 pontiac montana , It turned over at first then kinda backfired ,then would not turn over, cleaned all battery,and installed a new starter still wont turn over , I jumped the starter with a screw driver it turned over but wound'nt startI dont know how to use the viper remote start ; please help!!!!
Sam Challis
Level 2:
Sergeant:
  • Expert 177 Answers
  • Posted on Oct 22, 2017
Sam Challis
Expert
Level 2:
Sergeant:
Answers
177
Questions
Helped
51929
Points
623
If it backfired it's quite often timing. I don't know what motor you have but see if you can check the timing. If it's not the timing check if the car has a camshaft and or crankshaft sensor. If one of those go bad she wont start. Another quick test is to spray starting fluid or some carb cleaner into the intake and swing it over ... if it starts you have a fuel issue. Maybe the pump.
5 Related Answers
Anonymous
  • 12 Answers
  • Posted on Jan 22, 2009
SOURCE: No install instructions
email me at [email protected] and i will give them to you. i 've been doing install professionally for 10 yrs and have access to directechs (DEI technician website)
Anonymous
  • 69 Answers
  • Posted on Aug 20, 2009
SOURCE: back lighting for my viper 479v remote
you have to go in to the proramming mode of the remote to change this feature. you can access this by holding all 4 buttons on the remote at the same time. (or if you have the P button on the back you can hold it down by itself) you will hear 2 long beeps confirming the programming mode. at this time, you can change the settings by pressing 1 of the 4 buttons., each button will change a different function.
in no order------
1. Beep/vibrate or both
2. page or not to page
3.back light
4. hood, truck, or both
the remote will give 2 long beeps when it exits the programming
Anonymous
  • 171 Answers
  • Posted on Jan 08, 2010
SOURCE: disable viper alarm
Yes the best way is disarm the alarm and put in a Valet Mode
To activate the Valet Mode do the following:
There is a push button or toggle switch to disable the alarm (to engage the valet mode). Without knowing where this
switch is you won't be able to disconnect the alarm.
1. Put the key in the ignition and turn it to the "on" position.
2. Flip the toggle or hold the push button for at least 5 seconds.
3. The LED. light will stay solid on.
4. Turn the ignition off
5. Release the push button. If you have a toggle leave it alone in step 2
Anonymous
  • 344 Answers
  • Posted on Jan 28, 2010
SOURCE: viper remote car starter 479V
press and hold the ( P ) button until one long beep is heard, you now have 5sec to push the lock button to turn on or off the vibrate, wait another 5sec and it will automaticaly exit programming
Testimonial: "One word,AWSOME!"
Anonymous
  • 132 Answers
  • Posted on Apr 04, 2010
SOURCE: how to program viper 5701 remote
Unlock doors
Push and hold f button for 8-10 seconds until amber light is on solid
Push Remote start button for about 4 seconds till amber light flashes 3 times
Put key in to IGN position
Push valet (black button) one time and release
Push and hold valet button
Push either lock or unlock on viper remote
Key out of IGN
Test unit
The horn or siren may sound afterwards to indicate SUCCESS!!!!!!
Pontiac montana wont start
sound like ignition switch going bad or have loose wire to ignition switch.
2002 pontiac montana wont start won't turn over
First thing I would check would be the battery. Open the hood and make sure the battery terminals are tightly connected to the battery (try to turn them on the post by hand). If they are tight and you have a volt-ohm-meter you can check the battery charge yourself. If not you can remove the battery and take it to an autoparts store and ask them to check it for you.
2000 pontiac montana engine cranks over but will not start
Car not starting or turning over indicates towards multiple possibilities. It can be issue with battery or weak battery. But if battery checks out ok, then it can be starter issue or faulty alternator or problem with low fuel pressure or no spark at spark plugs due to dirty spark plugs or faulty ignition coil or injectors getting cracked or dirty and needs to be cleaned.
To confirm the problem, the basic troubleshooting is required.
Click this link below and follow the troubleshooting:------
http://technoanswers.blogspot.in/2012/02/car-starting-issues.html
This will help.
Thanks.
2000 pontiac montana Occasionaly, when turning the key to start, it will be dead dash lights will illuminate, but no life to engine to start it What's up?
check starter wiring for loose nuts, bad connetion. n what not. clean up terminals if needed n see if it turns over if not. check for power coming frm the yellow wire, or the smaller one. with the key held in start position, in no power you will need a starter solinoid. if you do have power go grab a starter n put it in,
My 2000 pontiac montana will start up then immediately die, if i give it gas to try and keep it running it sounds like it backfires through the fuel system
I smell a bad fuel pump.. Easiest way to check this is have someone turn the key but not actually start the car and you stand near the tank to listen for the humming sound a pump usually makes as it pressurizes the system. If you hear the humming sound then check the pumps PSI and see if it holds. Good luck
1helpful
Pontiac Montana starting problem
All 4 power wires go together on the large center stud on the solenoid.
The purple wire goes on the small stud.
The purple wire supplys the trigger signal when the key is turned to the start position.Since your solenoid is clicking when the key is turned to start this is working properly.
I would check battery connections and then check power connections on solenoid again.Make sure all connections are clean and tight.
Top Viper Vehicle Parts & Accessories Experts
oneStan
oneStan
ZJ Limited
ZJ Limited
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
