Question about DFI LANPARTY NFII ULTRA (LANPARTY NF2 ULTRA) Motherboard
Shut down my motherboard does not come on. one day it shut down. i have checked the powersupply and it still works. I have took out all of the cards and start using the motherboard. the only thing that is attached to the mother board is th vga card. I also tried changing the vga to a pic video card. what else can i do cmealso
Posted by cmealso on
rajesh raman
  • 656 Answers
Did u check the memory card clean the surface if its ok contact a chip level engineer because u might have problem with ur power section in ur mother board
Posted on Nov 30, 2007
It is sut down when working
check the lamp or lamp ballast
We supply original projector parts: lamp, bulb, Lcd
panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and
competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Feb 24, 2014 | Epson Projector Lamp For H284b Bare Lamp
Power automatic shut off after 5 seconds
check the lamp first
We supply original projector lamp,bulb,parts,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
Jan 29, 2014 | BenQ Office Equipment & Supplies
My motherboard is always shutting down automatically can i know the reason
probably overheating. try checking your heatsink fan if its working, and the fan on the powersupply.
Sep 07, 2011 | Biostar NF61S MICRO AM2 SE...
Not getting switching on.
Make sure that all the power cables required are connected properly to the motherboard, test the powersupply on another motherboard for example or use a powersupply tester.
Check that the power switch is connected on the right pins on the motherboard and that the switch works.
The motherboard should turn on - spin fans even if there is no memory, cpu or video card installed. So something is not connected properly, or either the powersupply or the motherboard is faulty.
Sep 20, 2010 | Intel Motherboard
My M2N-E wont boot to post unless I remove a stick of ram and start it. Then when I shut downa and replace the ram its boots normally. Battery - new Powersupply - new Vid card..tried several with same...
Is your new power supply unit stronger in WATTS to run your P.C. and all it's components? My neighbour had a similiar problem, 1 day he turned on his P.C. and it was lucky to get to desktop and if it did it restarted itself. We took out his 4 Ram Sticks and only 1 of them worked in the first Ram Slot. Then it would run normally. We discovered it need more Power, so he brought a new Power supply unit with more WATTS. That was all it was needed. You mention a new vid card, so did you buy a new Power Supply Unit with the same WATTS? If your P.C. never had a Vid card before or you have brought a newer 1 maybe it needs more power so the P.C. maybe struggling.
Only a thought, hope you sort it.
If this helps you out please give me thumbs up thanks..
Aug 26, 2010 | ASUS Ai Lifestyle M2N-E (ASKU49311)...
Pc not always booting,
blow out dirts on bord, then you pack the board to avoid any bridging with the cassing
Jul 20, 2009 | Computers & Internet
Errore codeoxe0000227
1. Full power down. Unplug the power cord from the Power supply. Then hold down the pc power button.
Try to boot the pc.
2. Open the case and reseat the graphics card, hard drive, and RAM.
3. Take out one of the RAM sticks if there is 2 or more. Swap the RAM sticks in different RAM slots.
4. Set the Cmos jumper to clear. Power up the pc. Power down the PC. Set the Cmos jumper back to normal position, power up the PC.
5. Unplug and replug all the power supply cables.
6. Check the powersupply function. Either by a powersupply voltage checker, put the powersupply in a different pc, or try a different powersupply in the problem computer.
Could be bad ram, motherboard, cpu, powersupply, videocard.
Jul 06, 2009 | ASUS P5P800-MX Motherboard
Screen went dead, unplugged the graphics card and
So basically you cannot get the pc to POST. Meaning you have just a black screen when you power on the pc, right?
First off, did you attempt to update BIOS before this happened. 90% of the time this is caused by a corrupt bios.
If you did not try to update BIOS before the problem started then try these troubleshooting steps.
Try to boot the pc.
If the video card is suspected to be damaged, try it in a other pc (friend's, mom's or dad's, pentagons' ).
if it is bad, there is your answer.
Jul 06, 2009 | XFX Computers & Internet
Computer will not boot.
Double check all connections and then remove anything not needed. Remove video card and try onboard video if available, remove all but one mem module, any cards and disconnect all drives. If you get video at this point, shut down and reconnect drives and components one by one. It helps if you have known-good parts to swapt as "new" does not always mean good.
Feb 17, 2009 | ASUS Computers & Internet
DFI LANPARTY NFII ULTRA (LANPARTY NF2 ULTRA) Motherboard Logo
Top DFI Computers & Internet Experts
Ekse
Lee Hodgson
Lee Hodgson
Carlo Barzo
Carlo Barzo
Are you a DFI Computer and Internet Expert? Answer questions, earn points and help others
