I need a schematic for a JL audio 500/5. Left front output has static. Not sure if it's a transistor or resistor. Even with no input source (on bench). Can't find a schematic anywhere!
SOURCE: Audio Amplifier JVC Model A-GX3
If the service manual is not available on the JVC websites then you should just Google search "JVC A-GX3 service manual" There are many websites that archive manuals. You'll probably have to pay for a copy. Why can't you disassemble the unit and see the output transistor numbers first? More importantly how do you know this is the fault?
Posted on Sep 22, 2007
SOURCE: jl audio 500-5
Assuming that you've confirmed that the speaker is in good working order and that the wiring isn't shorted in any way...
There are separate power supplies for the high and low amplifiers. It's possible that the one for the sub output has failed. If that's the case, the output transistors probably failed and that's what damaged the supply.
Generally, I'm willing to help people repair their amps but this is a large, complex amplifier and it should be repaired by a qualified technician.
Posted on Apr 19, 2008
SOURCE: Sharp Aquos 37" Audio Static Issue when watching DVDs
i have had to replace the hdmi input board on these units to fix them.
Posted on Jan 08, 2009
SOURCE: Quiet, low quality sound from one speaker, static from both
Take your fist and cram it up your ***.
Posted on Feb 16, 2009
SOURCE: Proton 520 Integrated Amplifier with quiet left channel
Hi...
Flush all the switches and controls with De-Oxit D5 or better.
Then get back to me.
Thanks
Posted on Mar 01, 2009
Jan 06, 2014 | Jl Audio 500/1 Car Audio Amplifier
Jan 07, 2011 | JVC RX-318 Receiver
Aug 27, 2009 | Audio Players & Recorders
May 25, 2009 | Jl Audio 500/1 Car Audio Amplifier
May 21, 2009 | Yamaha RX-V596 Receiver
Mar 13, 2009 | Panasonic SB-TP55 System
Feb 02, 2009 | Audio Players & Recorders
Jan 13, 2009 | Jl Audio 500/1 Car Audio Amplifier
Nov 28, 2008 | Jl Audio Slash v2 500/1v2 Car Audio...
Sep 20, 2008 | Monster Cable MPA 5150 SS Amplifier
41 people viewed this question
