Question about Cuisinart DLC-8S Pro Custom Food Processor
Cuisinart pro 11 won't turn on - Cuisinart DLC-8S Pro Custom Food Processor
Posted by Nancy on
Cuisinart manual for Custom 11
not sure but here's a Pro Custom 11 if that helps
https://www.cuisinart.com/share/pdf/manuals/dfp-11.pdf
Mar 29, 2018 | Cuisinart Food Processors
Need instruction manual for Cuisinart Custom Prep 11
Try this link:
Food Processors Product Manuals Cuisinart com
And look for the one that generally matches the era (design) of your machine, and then the bowl size.
All the best to you!
May 12, 2014 | Cuisinart DLC-10S Pro Classic Food...
I have a Cuisinart DLC-8S TX Pro Custom 11 Cups Food Processor that I purchased in spring 2004 and used only sporadically. Last week, I burnt the motor by using it to make fondant. Big mistake. I take...
If you already have a lot of attachments for this model, I would purchase a used motor unit. I got a complete setup at a yard sale minus the work bowl cover for $3 as a spare, and often see them at thrift stores priced quite inexpensively. You could also check ebay. Motor units routinely go for less than $25 including shipping. I'm pretty sure most dcl-8 series motors will work with you bowl and attachments. I like the quality of the older units better than the newer ones. And if you watch ebay closely, you can pick up a lot of pieces really cheaply. Good Luck,
Marc
Oct 21, 2010 | Cuisinart DLC-8S Pro Custom Food Processor
Cuisinart DLC-85 Pro Custom 11 Cups Food Processor. Checked motor as recommended, works fine. Put together as instructed, turned on and when I press the pulse button it turns it off. Help will be...
Whoops, when putting together I failed to insert the feeder cup.  When I did that it worked!  I should have more carefully followed the assembly instructions.  Thanks for your help.  What a great web site
Apr 17, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
Can't get cuisenart pro 11 to start
I am assuming you have a DLC-8S Pro Custom 11, and not another Cuisinart food processor.
Remove the work bowl and all other parts completely from base.
Plug the base in, and turn it on.
Use a pen to press in the dark grey or black button on top of the base.
If you hear a spinning or other noise, the motor is still good.
Now that you have verified that the motor is good:
Put each work bowl piece on one at a time - if you don't out it on one at a time, it will not lock in properly.
Put work bowl on with work bowl handle facing front, make sure bowl locks.
Put lid on with hollow feed tube facing the back of the food processor.
Put pusher sleeve into lid's feed tube, with sliding lock switch facing the front of the food processor.
You should now be good to go.
Apr 07, 2009 | Cuisinart DLC-2011 PowerPrep Plus Food...
None of the buttons work on my Power Prep Pulse 11-CUP
Remove the work bowl from the base of the food processor, and separate the bowl, lid, and pusher sleeve.
Plug the base into the wall outlet, turn the food processor ON, and then use a pen to press in the dark grey or black button on top of the base of the food processor - if you hear some kind of noise, then your motor is still good.
Put the work bowl on first, with the handle facing the front of the food processor.
Put the lid on, with the hollow feed tube facing the back of the processor.
Put the pusher sleeve in the lid, with the sliding lock switch facing the front of the processor.
Your processor should now turn on.
If your food processor still does not turn on, call Cuisinart and see if you are eligible for an in-warranty repair - it has a 3-year warranty.
-Tha Mp3 Doctor (also loves Cuisinart)
Mar 23, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
Cuisinart DLC- 8M
Those older Cuisinart food processors have motors that generally last forever. But a replacement bowl can cost $118.00 or more. The newer processors like the DLC-8S do have a 3-year general warranty and a 5-year motor warranty. The new DLC-2011, 2007, 2014 series etc. have 10-year motor warranties. I like the collect the oldies, but the new ones have few problems even though they are made in China. If an old processor's plastic breaks, you have to buy a completely new bowl set - if a new processor's plastic breaks, then you can buy a single component piece to solve the problem. Hope this helps.
-Tha Mp3 Doctor
Sep 19, 2008 | Cuisinart DLC-8S Pro Custom Food Processor
Lid won't lock
I've lost my instruction manuel for my Cuisinart Custom 11 ( DLC-8S) food processor and was hoping
you have one on file I can copy. Thank You in advance
Mickey Riley
Sep 02, 2008 | Cuisinart DLC-8S Pro Custom Food Processor
My food processor plastic container has never slipped on and off with ease i have to smash it into place and the double smash the handle to remove it from the base. I would like to get a new upper...
You can get a completely new work bowl set (not the original parts) from Cuisinart for around $118.00. You could also buy one from a shady eBay seller and see if the oldie works. I am a collector of these myself, but in reality, it is probably cheaper to get a new Cuisinart food processor - they are nearly as good as the old ones.
-Tha Mp3 Doctor
Jul 02, 2008 | Cuisinart DLC-8S Pro Custom Food Processor
Cuisinart DLC-8S Pro Custom Food Processor Logo
Top Cuisinart Food Processors Experts
Lawrence Oravetz
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
