Question about Dell E173FP 17" LCD Monitor
Dell 19' flat screen monitor
My dell 19'' flat screen monitor says it is in power save mode. The monitor light turns from green to yellow. It says to press any key or the power button, nothing works. On my cpu the numbers 3 and 5 are lit up. I unhooked the monitor cable and did the self check. It worked. I bought new cables. However, my computer is still in power save mode. Any suggestions
Posted by ctklori on
  • 2 more comments
  • ctklori Oct 25, 2007
    How do I check to see if my video card has become loose? ctklori
    My dell 19' flat screen monitor is stuck in power save mode. I did the monitor test and it was fine. I have changed my monitor cable with no luck. My monitor comes on with a green light instantly changes to amber. The numbers 3 and 5 are lite on my cpu.
  • ctklori Oct 29, 2007
     The numbers lit on my cpu are 3 & 4. The computer does not boot and it will not let me start  using the F1 key. My cd drawer will not open.  My monitor screen is black except for the Dell at the very beginning before it goes dark.
                                          ctklori
  • ctklori Jan 14, 2008
    We sent are computer to a tech who was going to try and check our motherboard to see if that was the reason behind our Dell going into power save mode. Our computer powered right up for him. So, we brought it back home and it worked for two weeks and then went back into power save mode. We again sent the computer back to the tech and it again powered right up. He did some test and the computer seemed fine. The next morning it would not power up for him again. He told us it probably needed a new power suppy. So we brought it home and guess what? It powered up again. So we have decided to not turn off the computer. It now goes to screen saver and then the computer monitor goes black. When we wiggle the mouse it comes back on and we are ready to go. Does this sound like a power supply problem, a mother board problem, or something else?
    Any assistance would be greatly appreciated. We are very frustrated with this computer and its need for ride in the car.
    Lori
Pedro
  • 233 Answers
3 + 4 lights is a "Card failure or conflict"
re-seat the video card and follow this
thanks for rating
Posted on Jan 14, 2008
  • Pedro
    Pedro Jan 14, 2008
    from your last comment...
    Yes this DOES sound like a power supply.
  • Pedro
    Pedro Jan 15, 2008
    Have you replaced the power supply?
    this should solve your problem, make sure the new powersupply wattage is the same or exceeds your current power supply value. labeled on the side of the powersupply.
arben pllana
  • 1,006 Answers
 Do you see the POST info when it boots?
check the video cable and card and make sure there are no bent pins.
have you tried to boot to safe mode or vga mode?
or:
In the Control Panel > Power Options -- what "power scheme" is selected?
What happens if you select "minimal management"?
it's possible the problem lies with the video card drawing too much load at the outset. Or the power supply has degraded and is not able to meet the current demands.
if there is an input selector on the front of the monitor have you pressed that? Also try using a DVI cable to connect to the monitor and vid card (if you can). Take the video card out and reseat it. After that i would consider trying a different video card.
Posted on Oct 26, 2007
  • arben pllana
    arben pllana Nov 01, 2007
    Now i think u have a problem with VGA or motherboard.To confirm it buy new VGA and try if still have a problem Try to CLEAR CMOS SETTINGS.Still not working just buy new MOTHERBOARD.
Anonymous
  • 363 Answers
Check that the graphics card has not become loose in the computer.
Posted on Oct 23, 2007
  • 1 more comment
  • Anonymous Oct 25, 2007
    1. Turn PC off
    2. Unscrew and open the computer case
    3. Push the graphics card back into it's slot (thats the one the monitor is plugged into)
    4. Close the case put the screws back in
    5. Turn PC on.
  • Anonymous Oct 29, 2007
    The monitor displays Dell but this does come from the computer.
    Did you check if the graphics card was loose yet?
    Tell us what make and model computer you are using, we might be able to find out what the 3 and 5 lights mean.
    Oops I meant the Dell display does NOT come from the computer. It comes from the monitor internally.
I have model 1975NW. When power is turned on, green light appears, then orange light. No picture is present.
The ORANGE light indicates "power-saving" mode -- when no "output" from a video-card is being detected, the screen will dim itself. Try a different monitor. Try a different video-card in your computer. Try your monitor on a different computer.
Feb 03, 2011 | Westinghouse 19" Widescreen Flat Panel LCD...
I have a dell monitor (2002) and all of a sudden when I try to turn the computer on I get blinking yellow light and (took to Best Buy and computer is fine) when I hit the buttons on monitor I get (power...
Hi Tomccaw,
In this case your monitor is working fine. Your system is going to power saving mode. To resolve that remove your RAM and insert it. It will fix your issue.
Jun 15, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
Dell E177FP monitor won't turn off in power saving mode
I had the same problem and I went to the first button on the monitor to the left(main menu) then with the button to the right (-) I scrolled down to factory reset. I also did the osd setting and I'm not sure what fixed it, but I havn't had the problem sence.
Jan 05, 2009 | Dell E177FP LCD Monitor
LG LCD monitor goes in power saving mode
That means theres no signal coming from the PC. either the PC is not booting up or the VGA coard is faulty.
Nov 25, 2008 | LG L1915S 19" LCD Monitor
Inspiron 530S Power Save Mode Loop
First you need to make sure that there are no other removable devices plug on the system, like usb, external hard drives, then if that will work try to go to the bios, press f2 when you see the dell logo, and go to the system setup, go to the boot device configuration and make sure that removable device is not the first boot device, if it is the first one choose hard disk and then second boot device ad cd rom/dvd rom and then disable the 3rd boot and the fourth boot device. Make sure to save the changes. And restart the system again. Once the computer is back and running try to go to support.dell.com and check the bios, download if there is a bios update for the system.
Oct 30, 2008 | Computers & Internet
Dell E193FP Problem
Probably a failing power supply
Apr 17, 2017 | Dell E193FP 19" Flat Panel LCD Monitor
LG L1832S Monitor not working
LG monitor shows a green light and then goes in power saving mode and a yellow light appears,
Aug 13, 2008 | LG L1915S 19" LCD Monitor
Dell flat panel monitor
It's a problem in the power supply section inside the monitor. It needs component-level electronic troubleshoting.
Jan 16, 2007 | Kogi l4bx-na ko 14.1" Flat Panel LCD...
Dell E173FP 17" LCD Monitor Logo
124 people viewed this question
Lee Hodgson
Lee Hodgson
Ekse
Thomas F. Schneider
