Question about Hotpoint SY36 Style Line Stainless Steel Electric Single Oven
Posted this several years ago. Don't know if it's the same oven. It's possible the oven sensor has gone bad or lost connection. Try cutting out the little plastic electric plug that connects the sensor to the oven wiring. Then hard wire it together with two small wire nuts.
If that doesn't work, you will need a new sensor, as we did. But when we installed it, we used the little plastic electric plug to connect it. Two days later it started acting up again.
The instructions said to hard wire it with two small wire nuts, but since it came with a plug it made sense to use it. Finally, even though it didn't make sense, I cut out the plastic plug and hard wired it. It's been about 3 years now and we've had no further problems.
THERE IS SOMETHING WRONG WITH THAT LITTLE PLASTIC ELECTRIC PLUG. YOU MUST NOT USE IT. HARD WIRE IT.
Posted on Mar 17, 2014
May 29, 2016 | Ovens
Feb 11, 2015 | Whirlpool Ovens
Nov 07, 2014 | Hotpoint Ovens
Nov 25, 2013 | Stoves Ovens
Aug 03, 2011 | Stoves Premier 900DCa Dual Double Oven
Dec 28, 2010 | Stoves Ovens
May 16, 2010 | Ovens
Apr 22, 2009 | Stoves 720EF Electric Double Oven
82 people viewed this question
