Question about Zebra Eltron LP 2824 Thermal Printer
I have a zebra model 2722 it is printing the same label repeatedly
5 Related Answers
Anonymous
SOURCE: Zebra LP2844 printer prints garbage
Sounds like you might be using a bad driver, or the printer is in dump mode.
Try hitting the green button and see if it says exiting dump.
If still having trouble, inside the printer it tells you that if you are having printing trouble:
  1. turn off the printer
  2. Hold down the feed button
  3. turn on the printer and at the third red flash release the feed button
  4. it will then feed some pagessome info and ask you to hit feed again to exit dump
  5. hit feed again and it will say exiting dump
This process re-reads the label length (so only do it with the labels you want to use in, or it will waste labels until you do it again with those in it) - but I'm suggesting it only because it enters and exits dump mode (which I have read can cause the garbage when you try to print).
Posted on Mar 11, 2009
Jim H
  • 62 Answers
SOURCE: An extra, blank label prints from a Zebra 2746e.
Check media settings in the printer driver. Check version of printer driver. Zebra printersuse an internal printer driver with their Zebra Designer software (Zdesigner driver) or a ZUD (Zebra Universal Driver) for other windows applications. These drivers can be downloaded directly from the zebra website.
Alternatively you can download the seagull scientific driver and use that instead. (used with bartender program)
Label skipping occurs if the media dimensions are not specified correctly. The important ones are label height, and media setting for type of media.
Perform a media calibration before you go changing settings. Power on printer, Hold top and bottom buttons in on control panel for 5 seconds, release bottom button only then when printer starts feeding labels release top button. When printer finishes press feed button.
Posted on Apr 18, 2009
Anonymous
SOURCE: ZEBRA TLP 2824 LABEL MAKER PROBLEMS
I've had this problem. I changed the margins and it solved it.
Posted on Jun 09, 2009
Anonymous
  • 31 Answers
SOURCE: Zebra 2746e will skip leaving a blank label while printing.
You need to calibrate. Hold down the feed key while powering the printer on, then let go. The printer will calibrate, print a config label, then fo into dump mode. Press the fee key again to go out of dump. Of your issue persists, there could be a problem with yoru media, or with the commands that you are sending to the printer.
Posted on Jan 31, 2010
Anonymous
SOURCE: print spooler resends data if long delay between labels zebra
We are considering different print drivers. Zebra's tech support is horrible and staffed with lazy, blundering idiots.
Posted on Apr 05, 2010
Why is the text printing on Zebra LP 2844-Z label incorrectly spaced?
Zebra printers are not really made to print PDF files, if the only option is PDF I'd recommend switching to print on a laser. Also open the PDF and see if they are correct in the original doc
Oct 06, 2015 | Zebra Office Equipment & Supplies
Zebra 105sl printer labels print too small
There are 3 different DPI Printheads for Zebra printers if you print a label set up for a 200 DPI Printhead on a printer with a 300 DPI Printhead installed it will be about 66% of the size.
Feb 13, 2014 | Zebra 105SL Thermal Label Printer
I am trying to print a label on the zebra 105SL but the font and the "text boxes" are printing too large like it is zoomed out - how do I resolve this issue?
I am trying to print a label on the zebra 105SL but the font ...
www.fixya.com/support/t5406223-am_trying_print_label_zebra_105sl
Jul 11, 2010 - I am trying to print a label on the zebra 105SL but the font and the "text boxes" are printing too large like it is zoomed out - how do I resolve this ...
db:: 4.67::Crystal Report Label Won't Send To Zebra k9
www.hivmr.com/db/k99xad9dfspspddfs1scm9fzxxkdz9dj
My routine can print the label to any other laser printer, but the Zebra. ... I am tryingto find a way to print actual time a smartform label gets printed out on a zebra ... In this i want to changeCross Tab expert Row Label Font,Cross Tab expert ..... And labelpaper too. ..... DB:2.73:Zebra 105sl And Crystal Report Label Issues 1d.
db:: 5.16::Help My printer is printing in 3x5 documents and I ...
www.hivmr.com/db/xkzpajp81937ap7zdf87sdmsxmcm179m
DB:4.06:Printing 3x5 Continuous Feed Labels On Hp Officejet 6100 d8 ... Are they toosmall? ... I want to help you but I am not sure I can be of much help until I know what kind ... If the paper size is 3.5x5 but you are trying to print a 3x5 photo (which seems to be ...... I have a label format issue on a Zebra 105SL label printer.
db:: 4.15::Custom label sizes md - Hivmr
Jul 11, 2010 | Office Equipment & Supplies
Label alignment
see if you can download from here: http://www.zebra.com/id/zebra/na/en/index/resource_library/manuals.results.html
Z4MPlus Users guide is the fourth one down.
Mar 12, 2010 | Zebra Z4Mplus Label Printer
Hi, My printer model is TLP 2844.i m facing the problem in printing. The printer is hang after one or two lines printing and red LED are ON and I press Green button repeat same as before. Please solve my...
Solid red light. This indicates the printer is in an error state and will not print until the error is cleared. Check to make sure the printer is not out of labels or out of ribbon if it is a TLP model.
A solid red light will occur if
  • the printer is out of labels
  • the printer is out of ribbon ( TLP models only )
  • the printhead is open, not latched down all the way. Press down on the top cover of the printer to see if the error light clears and goes to green.
  • the ribbon spool is slipping on the ribbon spool holder on TLP models:
These 2 links will help you troubleshoot the problem:
https://support.zebra.com/cpws/docs/eltron/2844/28x4_rib_det.htm
https://support.zebra.com/cpws/docs/eltron/2844/2844_tsguide.htm
Click on this link. Or copy and paste it into your browser.
If I could be of further assistance, let me know.
If this solves your issue, please be kind to rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Mar 15, 2009 | Zebra TLP 2844-Z Thermal Label Printer
When printing more then 10 labels from Acrobat some of them are missing
Hello!
Dear
I need ur assistance about this types of Model TLP-2844,LP-2844,S4M,S-600,105SL,110xiii,140xiiiPlus,Z4M,Z4MPlus,How can I Install a Printer With Label and Ribbon?Can U help me regarding this problem?I am waiting for ur assistance.If possible please send me a video file about how to Install a Zebra Printer with label and Ribbon.
Dec 13, 2007 | Zebra Z4Mplus Label Printer
Zebra Eltron LP 2824 Thermal Printer Logo
37 people viewed this question
Top Zebra Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Marvin
Marvin
Ekse
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
