Its reaaly annoying that i cant get incoming call but shows missed call notification later on my iphone 4. Person who calls says that phone gives user busy signal after one ring.
SOURCE: iphone wont ring
Did you check to make sure that the "mute" switch on the left side of the iPhone is turned off (if you see an orange dot, it means mute is turned on). It may not be vibrating either because in main Settings - Sound - you haven't turned on "Vibrate" when on Mute.
I thought my iPhone was broken until someone pointed out this to me.
SOURCE: IPhone - Can't hear incoming calls. Does not ring or Vibrate.
I had a similar problem....it was usually after I unplugged the headphones....the phone thought they were still attached, therefore, nothing came over the speaker......try plugging in the headphones, then unplugging...that worked for me.
SOURCE: iphone can't receive calls
check in settings/phone to see if you have maybe turned on call forwarding and it is being forwarded automatic to your voicemail box number
SOURCE: phone won't ring in sleep mode
I had the same problem with my iPhone the only way I was able to fix it was to re-flashed the latest 2.2 firmware. Power phone off, power on by holding power and home at same time, hold power for ten seconds and then release still holding home key for another 30 seconds to put phone in DFU mode. Then plug into iTunes it will detect phone in recovery mode and allow you to re-image
SOURCE: Iphone hangs during standby mode.
If iPhone won't turn on, or the display freezes or doesn't respond
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
