When taking pictures the screen turns white and says camera error. Turn it offhand back on it will take more pictures
If you have a camera error, or a system error, you should switch of the camera, remove the battery and reinsert the battery, before switching it on again. If this happens frequently you should contact a authorised Sony service centre. While you have the battery out, you could check if the contacts are clean, free and shiny. (on battery and in the camera)
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, press the RESET button located above the PHOTO button which will change all settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa
Camera is sony dslr a330
