SOURCE: I can't select aux when I plug my ipod into my Pioneer stereo.
I think this can be done with the stereo on but you have to hold down either the e button or 1 of the buttons on the right side of face(not audio)maybe and a menu will pop up and you should run into a screen that ask off on or off you will want it on and then you should be able to access ur ipod by pressing the source button.Hope this helps.
SOURCE: Can't get auxiliary to work on Pioneer Mosfet Head unit 50x4
you have to turn the AUX input on through the function menu which can be accessed by following these steps
1. with the unit on. press and hold the source button unitl the unit turns of (or goes into demo mode, which is fine)
2. depending on the model that you have, you will have to press and hold the
(volume button or the audio button), until a menu is displayed.
3 . toggle through until you find AUX 1 and AUX 2. i would turn them both on and see which one you have plugged into, then you can go back and turn the other off.
4. once you have change it to ON. press the source button to turn on. the aux option should now be in your source options.
5. also, while on AUX, you can go into the audio settings and turn up the SLA (sound level adjustment) to +4
hope this helps
SOURCE: cannot get rear aux input source to work
The type of plug on the front aux is a 2.5mm plug similar to what cell phones use. You need a stereo 2.5mm to 3.5mm adapter, then you can run a chord with a 3.5mm jack on both ends to an iPod or some other type of mp3 player.
SOURCE: How to set Pioneer DEH-P440 AUX input ON
hit the 'source' button.
you might have to turn aux on first, in that case, turn the deck off, hold down.... fuction then turn it on.
Testimonial: "FUNCTION will bring up RANDOM (ON/OFF),REPEAT(ON/OFF),PAUSE(ON/OFF), and something called T-SCAN (ON/OFF), but nothing else. Still no AUX."
SOURCE: I have a pioneer cassette player, how can I input
ipods come with a transmitter that plugs into the ipod. it has an fm radio instruction manual tells you what frequency to tune to and how to select the station on the transmitter. this way you dont wire anything into your cd player, providing it has fm radio.
