Hi my mw511 fisher and pykell won't fill with water. If I take the tap off the back and then replace it works for a while then happens again. No blinking lights
SOURCE: fisher & paykel (mw511)
check out the DRAIN MOTOR PUMP , its a small motor with 2 hoses connected to it , it could be clogged , need to remove it , inspect inside the impellers for any debri , clean it , re install and try again , hope this helpful AJ
SOURCE: Problem with F&P MW511
Dear friend,
ngfam at you service!
You can not fix this problem your self!!!
This sounds like it will only fixed by service then you will be happy again!!
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
BUY SPEED QUEEN NEXT TIME AND HAVE IT FOR 25 YEARS! THAT'S WHAT I HAVE!
Happy to assist you,
PS. PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
SOURCE: Problem with Fisher & Paykel MW511 toploader washing machine
Having the same problem. Any ideas at all? It's really frustrating.
nwesthamz
Rank: Apprentice
Rating: 75%, 1 votes
mw511 fills with water but cylinder isnt spinnig and when it stops
filling nothing happens. However sometimes it will go complete cycle
ans a noise can be heard on spin cycle even though it is not spinning.
As thoiugh the motor is not engaging with the cylinder
Was this helpful?
Yes
No
SOURCE: No spinning action on my MW511 Fisher and Paykell
Hi just read your posting.Now with the error code you have shown it tells me you have an out of balance fault.To find out if the fault is with the out of balance switch or the motor controller you will need an electrical test meter. the reason for this is to test the switch for conductivity,not to test for power or anything dangerous.Have you or can you borrow an electrical test meter to test the switch?please reply and I can guide you throe the repair of this fault.
