Led is now dimmer how to take it back to manufacture settings
To fix the dim brightness level, remove the battery and pull the plug out of the mains power. Leave it disconnected for at least 5 minutes then plug it back into mains power. You should find the brightness has retuned to normal. I have 3 of these Clock Radios and the picture attached shows the comparison between dim and normal. For some unknown reason they intermittently decide to dim themselves. This may be why Sony included a dimmer in the next model up ICF-C318. Anyway I hope this helps
BIG thanks. It works for me! Now I can read the time at daytime.
BIG thanks! It works for me. Now I could read the time under daylight.
Thank you!!
I worked great!
Thx so much!!! I know how annoying it can be when u want 2 c what time it is, u look at that clock in the daytime, u can't read it cause it's dim.
Check out my YouTube channel @https://m.youtube.com/channel/UC25pNIu4D...
?? thank you!
Press the snooze bar a few times until desired brightness.
Hello, i managed to some how change the dimmer on my clock (after the kids pressed all kinds of buttons and it jumped to super bright). Not exactly sure which one goes first but it is either the DST or the Time Zone button. These two buttons are the clue. I pressed like crazy (noy too hard) and suddenly managed to do the dimming in 3 or 4 brightness steps. But then it throws off the DST, So when you slightly press the DST button it jumps to auto/ on and then off....and then i think i pressed the Time Zone button and the dimmer started to change. I tried to do it a few times but got frustrated with it. But bottom line, these two buttons are your key. Also do not press too hard, just gently and play with them, you will see the dimming suddenly change.
