Question about HP Officejet 4215v All-in-One Printer
Faxing How can I make this device stop printing a confirmation page? What must I do to make that stop?
Posted by marker on
Thomas Christopher
    Genius:
  • 1,601 Answers
Press Setup , press 1 , and then press 1 again to enter the Automatic Reports Setup.
  1. Press the Right Arrow until Every Error appears in the display, and then press OK
Posted on Nov 19, 2007
I have a pro4000 series. How can I stop it from printing a confirmation page for the fax?
On the control panel of your printer, press on the Home Icon > Setup > OK > Fax Setup > OK. Go to fax reports and turn off print confirmation page.
Aug 15, 2012 | Lexmark OfficeEdge Pro4000 Inkjet...
How to stop to print the journal after send fax everytime?
Sending Confirmation
This report shows the fax number, the number of pages, elapsed time of
the operation, the communication mode, and the communication results.
You can set up your machine to print the message confirmation report in
one of the following ways (see page 5.3):
• Automatically after each transmission (ON)
• Automatically only if an error occurs during transmission (ERR)
• No report printed at all (OFF). You can print this report manually at
any time you want.
SENDING CONFIRM - A confirmation report shows whether the
transmission was successful or not, how many pages were sent, etc.
Select ON to print a confirmation report automatically each time you
send a fax.
Select OFF to turn this feature off.
Select ERROR to print only when an error occurs and the transmission
was not successful.
Nov 27, 2010 | Samsung SF-5100 Plain Paper Laser Fax
I would like to have the device print a Fax Confirmation for all fax sent and received. HP Officejet J4680 All-In-One
Follow the steps below to enable the Fax confirmation on Sent and recieved.
On the printer :
  1. Press Setup (c01461502.gif ).
  2. Press the right arrow button (c01185072.jpg ) to select Print Report , and then press OK .
  3. Press the right arrow button (c01185072.jpg ) to select one of the following options:
    • On Fax Send: Print a confirmation page every time you send a fax.
    • On Fax Receive: Print a confirmation page every time you receive a fax.
    • Send & Receive: Print a confirmation page every time you send or receive a fax.
  4. Press OK .
Thank you for contacting FixYa
*Please rate this solution with Thumbs Up
Nov 24, 2010 | HP J4680 Office Jet All-In-One Printer
Photosmart c309a fax confirmation?
To enable fax confirmation via the device control panel
1. Press Setup.
2. Select Print Report, and then Fax Confirmation.
3. Select one of the following: On Fax Send, On Fax Receive, Send &
Receive
4. then press OK
Dec 11, 2009 | HP Photosmart Premium C309A All-In-One...
Printing out a confirmation page for a document automatically
press FUNCTION, 7, 4, SET, 1, 2, SET, 2, SET, STOP...It will print everytime you fax out a document.
Oct 02, 2009 | Panasonic PanaFax UF-8000 Laser Fax
Confirmation pages
Press
Function
74
set
12
set
set
stop.
Feb 24, 2009 | Panasonic PanaFax UF-8000 Laser Fax
Wont print anything even atest page
what operating system and how do you connect printer to computer?
check under device manager if usb if you have usb printing support from universal serial bus controller if using usb and check status of printer from printers and faxes if using windows based platform
Apr 02, 2008 | Epson Stylus Photo R2400 InkJet Printer
Confirmation Page
Check the link -- if this is the correct device page 44 of the first english manual has the code for changing the confirmation page setting.
http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Fax-Printers/Plain-Paper-Fax/Copier/model.KX-FG2451
Dec 10, 2007 | Panasonic Panafax UF-550 Plain Paper Laser...
Confirmation pages
press function
press dataregistration
press set
use scroller up and down to select the function that you want to do, there's a lot of function, like user setting, report setting vvvvv.
select user settings, then scroll up or down
select activitiy report, then set it auto print off
will help you, play around with it.
Oct 22, 2007 | Canon FAXPHONE L80 Laser
HP Officejet 4215v All-in-One Printer Logo
60 people viewed this question
Ekse
Thomas F. Schneider
